Question about Fuji FinePix 6800 Zoom Digital Camera
Lens cover stuck open, power wont come on
I turned the power on to take a picture. It chimed like it was coming on. The lens cover opened, but the lens did not pop out. The power never really came on - none of the displays work - and I cant get it to come on or get the lens cover to close.
Posted by hooves on
julianashley
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I had a similar experience - camera had been out of use for some time: the battery has become "tired" i,e. does not hold charge for as long as it should or deliver as much current as it did when new which explains why the most power-intensive action i.e. pushing the lens around is beyond it - the battery indicator was low after a few attempts. Eventually after leaving it on until it switched off and recharging for a day a few times it is working much better, though I will be replacing the battery. I am a fan of good but dated technology, I have to admit.
Posted on Nov 21, 2012
Dennis Leefarr
    Problem Solver:
  • 6 Answers
I have been told by a camera mechanic i contacted on line (in America) that there is a fuse within the camera which is very small and soldered onto one of the boards. I was unable to get a precise location and the only details were that this component was either white with black writing or black with white writing.This may have a bearing on your problem.
Dennis
Posted on Nov 26, 2007
Lens error
that could be the lens cover not opening all the way, try and look at the lens as if you were doing self-portrait, and power on. if lens cover opens all the way but lens doesn't come out, the lens might be stuck or motor broke.
Sep 06, 2009 | Canon PowerShot SD850 IS Digital Camera
My lens is stuck!
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Feb 08, 2009 | Polaroid T831 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
My lens does not open or extend.
my camera is doing the same thing but i dropped it once and ever since it won't open anymore... it's definetely broken right? this sucks
Jun 15, 2008 | Canon PowerShot A520 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lense Cover Stuck
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 01, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera lens cover is sticky
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Fuji FinePix 6800 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
