SOURCE: END OF CYCLE KEEPS BEEPING WHILE WASHING
Maybe the machine is telling you that your load is uneven, When going through a spin cycle it will detect if the load is too heavy on one side. Just open the door and spread the load evenly. good luck.
SOURCE: The wash cycle ended but did not do the last final
Hello- If the drum does not turn in either wash or spin I would check the belt drive.
SOURCE: Have a 3 yr washer that at the end of the wash it stops!
Thanks for writing to Fixya.com.
This sound like a loose connection in the wiring in the machine. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards.
Thanks for contacting Fixya and please accept the solution if it has helped you.
SOURCE: Washing Machine is leaving lint on everything.
If nothing works you have to either,
1. change your washing machine/filter
or
2. Use a Lint Roller to remove lint on dark-colored clothes
