Question about Bush DVD142RC 14 in. TV/DVD Combo
My daughters 24 inch bush led/ dvd combi has started to play dvds in black and white. the normal tv picture is fine
Posted by Vilma Vadeikaite Ali on
Thomas Smithbrother
    Top Expert:
  • 3,698 Answers
Most Big box stores have a DVD cleaner disk, located in the electronics section, which is fairly inexpensive. I would try that first.
Posted on May 20, 2014
5 Related Answers
Mike Chamberlin
  • 88 Answers
SOURCE: I have just bought the Bush combi A322d hd ready
Is your antenna "omni" or "uni" directional? "Omni" means you won't have to aim the antenna but "uni" antennas have to be pointed in the direction the nearest tower/s. You'll want to go to AntennaWeb.org and enter your address. This will show you locations and distances of TV towers in your area. My location is over 39 miles from any tower so I get virtually no reception with regular HD antenna. If your more than 20 miles you'll need to get a fairly high gain antenna and have to aim it in the direction of the TV tower.
Posted on Nov 19, 2009
Anonymous
SOURCE: BUSH TV/DVD combi
connection between tv and dvd might be wrong or need to be checked
Posted on Dec 03, 2007
Anonymous
SOURCE: connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
hi my bush modle is btv183dvd\c i live in iran but i didnot buy this in iran well i listened that this modle has code ( if you kepp the negative switch volume on your tv & in that time push & keep the number 6 on controler ) you can see very much codes please dont change thoese
but i changed thoese and know i cant search for channel and it cant show that channel that befor time show that
please help me thank's
im armin
Posted on Jun 28, 2009
Anonymous
SOURCE: Hi can anyone please let me know the code for 4 in
I'm looking too, but no luck yet. I'll let you know if I succeed.
Posted on Feb 10, 2011
gopakumarg43
  • 76584 Answers
SOURCE: Hi there, I purchased a
Hello
There are two possibilities for this fault. The first one is the spinning problem of disc inside it. If loaded disc does not spins, the mechanism will eject it. The reason for this is damaged sled motor. Sled motor is one which spins the disc inside at high speed. It can be replaced. The second reason is of Laser Pickup Unit itsef. If it does not emit laser beam, the main system circuit will recogonise as there is no disc in the tray, and play function is energised, and will eject the tray out. Check for the first one. This is most comon fault with DVD players. OK.
Posted on May 30, 2011
Testimonial: "I will give it a try, thanks...."
Bush tv combi led24265dvdcntdfvpxy dvd will not play.
Have you tried DVD lens cleaner, More than one shop bought DVD disc and 1. Menu 2. Scroll down to installation press ok 3. Scroll down to first time installation 4. Scroll left for yes press ok then once reset follow on screen instructions to set this back up.
If this failed follow link below:
https://www.argos-support.co.uk/6693954-bush-24-inch-hd-ready-smart-tv-with-dvd-player-black
Jul 14, 2018 | Bush Televison & Video
Bush tv / dvd combi modle .. led24127fhddvdp as started to play in black and white how cam I change it back
Make sure you have the correct country chosen in the initial setup. If the TV is setup for an NTSC country and you're in a PAL country or vice versa, the picture will be in Black and white.
Feb 08, 2017 | Bush Televison & Video
My combi tv only plays dvds in black and white
mines just gone the same way after less than 2 years of having it and Finlux do offer to repair but it does have a year guaranty
dont think i'll be buying another.
Finlux (JTM)- 0800 737 247 -Collections/spares/chargeable repairs/returns dept.- Select option 2
only thing to try i'm affraid
Apr 12, 2014 | Finlux 19H6030 19" LED TV 1280x720, 50 Hz,...
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
My daughters 24 inch bush led/ dvd combi has started to play dvds in black and white. the normal tv picture is fine. does any clever person out there know how to fix this problem? would be very grateful
Laser pickup unit fault. It should be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 14, 2012 | Bush DVD142RC 14 in. TV/DVD Combo
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Alba led16911dvd
my dvd combi works fine but only plays the dvds in black and white and the dvd part of the remote doesnt work
Jan 19, 2012 | Albatron Televison & Video
Bush tv/dvd combi
your daughter has done nothing wrong, certain dvd,s have region codes for different countries.you can program the player with your remote, but you will need the hack number.i,m looking for it myself, so if you find it,pass it on!
Oct 17, 2008 | Televison & Video
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
BUSH TV/DVD combi
Oct 07, 2006 | Bush DVD142RC 14 in. TV/DVD Combo
Bush DVD142RC 14 in. TV/DVD Combo Logo
Top Bush Televison & Video Experts
Raj Patel
Tom Chichester
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
