Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Boot up when the powerbook is attached to my laptop the laptop won't boot. It won't get past the starting screen. it won't get to the welcome screen unless I first unplug the powerbook then boot my computer.
Posted by mommaredfox on
Anonymous
The "boot from USB" has to be disabled in your BIOS. If you don't know how, try to put the disk in another USB port - it might work.
Posted on Nov 05, 2007
Mac powerbook grey screen with apple and frozen
if the root is bad, you'll probably need to repair the disk from a boot disk.
Apr 09, 2014 | Apple PowerBook G4 Mac Notebook
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Acer aspire 5349 won't boot
I had the same problem. I clicked on F2. in Bios screen I press f10 (save and exit), and windows started.
Apr 02, 2012 | Acer Aspire 9300-5349 Notebook
Powerbook g4 17inch. when turned on iI get grey screen apple motif and loading symbol going round. when I start with start button and c key held down I get a mssg in top l/h corner saying : welcome to...
hmm well you could do 1 of 2 things Re install the OS, or Call there Amazing Tech Support cause there might be another way. Apples Tech support is by far the best I have ever dealt with.
May 13, 2011 | Apple Powerbook G4 1.33GHz 512mb 60GB...
Apple Macintosh PowerBook G3 Start-up problem
Your mac doesn't recognize the system folder. Try to find the original boot disks that came with the machine, and see if you can mount the hard disk while booting from the CDs. If you can, I'd backup the data as soon as possible and reinstall the operating system, including a full hard drive reformat. If you can't see the hard drive from the boot cd, another option is to hold down the T key during startup to boot the mac into "target disk mode" - this will allow you to hook up the g3 to another computer as an external hard disk in order to back up the data.
Oct 21, 2009 | Apple PowerBook G3 Mac Notebook
Powerbook g4 going to white screen only!!
Do you have any external harddrive attached to it? If so, remove it before restarting. Try to start it up in safe mode by holding the Shift button down at startup: http://support.apple.com/kb/HT1455
Mar 24, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook won't start up
If you have the original install CD or the OSX CD, boot to CD. To do that you must insert CD, restart PowerBook and hold letter "C" on keyboard while computer is starting, then take the first steps towards installing the OS, when you get to the bar on the top go to Tool>Utilities>Disk Utilities then select the drive a do a disk repair. That may fix the problem and bring your system back to booting normally.
Mar 15, 2009 | Apple PowerBook G4 Mac Notebook
Start up
Try rebooting into safe mode, then emptying your trash and restarting to normal operation. In safe mode, all internet is dissabled, so dont go trying to fire up the bluetooth or wi fi. The systme trashes unneccessary fonts and cache that can complicate the boot up.
If that does not remedy, try getting anothe rmacintosh running 10.3 or higher and a firewire cable. Boot your powerbook into TARGET DISK MODE and from the other mac go to UTILITIES and run permissions on your powerbook ( it should be on the left pane in DISK UTILITIES )
These are a few quick fixes, if they dont remedy the situation, keep me posted and try providing more info, like which version of osx, what you were downloading, and what apps were open when it was last functional.
Keep me posted.
Nov 19, 2007 | Apple PowerBook G4 Mac Notebook
Stuck on the Windows XP Welcome Screen
One of an important file needed to boot up your laptop, or your hardware is loose. Try taking out the ram and putting it back in.
Aug 28, 2007 | Compaq Armada M700 Notebook
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
154 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
