Question about Maytag Atlantis MDG6400AW Gas Dryer
Why will my MEDB400VQ maytag dryer not start - Maytag Atlantis MDG6400AW Gas Dryer
Dryer starts but shuts off after a few minutes
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Maytag Dryers
Washer is noisy in spin cycle and won't spin water out
but clutch or loose worn belt, also check bad motor coupler
Aug 02, 2014 | Maytag Bravos MEDB400VQ 29" Electric Dryer...
Not dryingi
im not completely familiar with these but if its "cut off" again.does it have more than one rehostat .normally uk machines have inlet temp,and two more in exhaust stream ,one for upper temp.one for lower temp.they work at different temps so assume it was replaced with correct temp ratin.in uk they come as threes sometimes.ie replace all..only other problem is the exhuast is blocked or flow reduced due to fluf causing machine to run to hot .
Jun 13, 2014 | Maytag MEDB400VQ Dryer
Problem code F22 flashing
http://www.appliancepartsquick.com/MaytagBravosDryerFaultCodes.html exhaust thermister in simple terms is a small round can shaped sensor which turns on/off heating element as the air temp exiting machine rises or falls to stop machine getting to hot and burning out components,reletivly cheap to buy and faily easy to fit depending on youre capabilitys ,if in doubt call a friend who can help or quallified engineer
Dec 31, 2013 | Maytag MEDB400VQ Dryer
DRYER HAS LIGHTS BUT WILL NOT POWER ON, WHY?
If you have 220 Volts going to the dryer then most likely Its the Thermal Fuse
Part # 3390719 On this Model the Thermal Fuse is located in the front of the
Dryer not the back. Good Luck
May 15, 2010 | Maytag MEDB400VQ Dryer
Maytag MDE4806AYW - Clicks but does not start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 12, 2010 | Maytag MDE4806 Electric Dryer
The fan doesn't move
Replace the blower wheel located in the blower housing .
Aug 09, 2009 | Maytag MEDB400VQ Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
