Light is on and no power to woofers P450.4 4channel amplifier
SOURCE: No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
SOURCE: Power not running constantly through amplifier
You might check your ground cable for poor connection. If it is attached to the painted chassis of the automobile, the paint needs to be scraped off a little. Or go to a local audio shop or Walmart and buy a cheap capacitor. It is supposed to hold power in itself providing the amp constant power for just this reason.
SOURCE: no power up on ssl f2.200 car amplifier
Yes it does. You should be able to use the blue/white wire to turn it on if you are using an aftermarket radio.
