SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
SOURCE: need online manual for Craftsman 13.5hp 30
Locate your Sears Model number on your mower, go to www.searspartsdirect.com follow their instructions and you can download your needed manual
SOURCE: i need a pully and belt diagram to put the drive
These are a pain. You can go online with model number & get the diagram. Its the same as a John Deere. You will have to loosen the steering arm 7 rasie the steering wheel just enough to pass the belt thru. Make sure you mark its position for reailigning before disconnecting. Diagram should also be in your owners manual. Goo dluck with this one
