Question about Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
Jacuzzi hot tub replacement jets - Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
J.D. Browning
  • 2,760 Answers
Your local jacuzzi dealer should be able to source you some parts , but i can tell you if it's only a o-ring failure these are avail from your local hardware store , as most jets are rebuildable , some are not look at back for screws to see if they are or not
Posted on Sep 19, 2014
2 Related Answers
Kieran Ruppert
  • 990 Answers
SOURCE: jacuzzi hot tub pump. Put new pump and motor in
Check your suction plumbing to be sure it is sealed and tight. Then force some water through the pipe to see if anything is blocking it.
Posted on Nov 28, 2010
Gene Haynes
  • 5391 Answers
SOURCE: Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Dec 09, 2012
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Hot tub jets and heater turning off to fast
??? - turning off too fast? Problem exactly?
Are you saying that the jets don't stay on for the 15 minute cycle once you push the Jets button? If that is the case, then your circuit board is failing - the time chip is the problem. A certified Jacuzzi service center should be able to change the Dallas Time Chip.
Jan 04, 2014 | Jacuzzi Pool & Spa
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
One of the jet assemblies on my Jacuzzi 325 hot tub popped out and I can't get it to stay back in. i've been pushing it in as hard as I can but when I turn the pumps on it pops back out. Should I be...
once a jet face has fallen out of a hot tub that means the insert has failed and is broken. you will need to locate a new jet insert. Jet inserts have little tabs on them that hold them in place and when they get worn out the jet face will fall out into the tub.
Jan 29, 2011 | Jacuzzi Home
I have a Jacuzzi Z110 hot tub. the top control is broke (pn 51422). Can i use a digital top control PN 33334.
When dealing with a big manufacturer like Jaccuzzi, it is unwise to swap top side controls. They make theirs proprietary on purpose so that swapping is more difficult (especially jacuzzi).
If you use the wrong one, the buttons on the controls will be misleading (such as temp up button cycling jets, or the ozone button cycling the lights, etc)
I would use manufacturer part.
Oct 01, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V Logo
66 people viewed this question
Top Jacuzzi Pool & Spa Experts
Mike
john h
Marvin
Marvin
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
