Question about Wells Kitchen Appliances - Others
How can you change electric fryer to propane
It's a f-49 deep fryer serial# R-24529 also has LR -10836
Angel Joseph Jr.
  • Wells Expert
  • 684 Answers
It is not economical nor even possible to convert electric fryer to gas fryer since the tank construction and parts are very different.
Posted on May 20, 2015
5 Related Answers
Anonymous
SOURCE: change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Posted on Apr 09, 2009
Anonymous
  • 77 Answers
SOURCE: DEEP FRYER WONT HEAT
have you tried taking out all of the oil and washing it realy good I know that mine wasnt working and thats what i did and it started heating up again
Posted on Feb 19, 2008
bigg t
anthony james
  • 640 Answers
SOURCE: deep fryers
Yes you can,you need to change the regulator,gas valve and orfices.
Posted on Jun 06, 2008
Anonymous
SOURCE: 5l bravetti deep fryer
i called 1800-798-7398 mine is the 5liter fryer, and he needed the model number and date number on the back of the unit *difficult to see/ black plastic, but once I told him what this info was, service tech advised me to push a reset. It looks like a hole where a screw would be .. but I did as he suggested took a pen, pushed it in the hole * i could see no screw in the hole.. and when I plugged it in, turned it on, it started to heat up right away! Hope this is helpful for you! Call the number, Mine was a gift too, I had no receipt. He also wanted to know where it may have been purchased. I knew mine was from canadian tire. All is good. Call the number with model, and age date on hand.. and i am sure they will help you out too. They gave me an account number for refrence if i have any further questions/probs.
Posted on Jun 11, 2009
Anonymous
SOURCE: deep fryer from a restarant to change over to
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Posted on Jan 05, 2010
I have a Vulcan deep fryer. Converting from gas to LP. Changed out the orifices. Bought high pressure propane regulator. No smell of propane into fryer. Plug unit in and no power to electric...
Hi There. You have not mentioned that you also replaced the spring inside the gas valve suited for propane, please check. I strongly advise not to modify the unit's ignition system nor bypass safety device, this is for your own good. Check the gas valve spring first.
Nov 14, 2013 | Kitchen Appliances - Others
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
What is the cost involved to change from gas to propane on a deep fryer
I'm not sure how much will it cost to convert a fryer from propane to natural gas but you will be needing a conversion kit in doing this. Try to visit pitco website at www.middleby.com and look for the nearest distributor on your area.
Jan 18, 2011 | Pitco Frialator SG14 Deep Fryer
Deep fryer from a restarant to change over to propane need orfices
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
Cecilware deep fryer
Goto 3wire.com.Search the site with the s/n.To do the conversion you need to change the pilot,burner orfices,gas valve and pressure regulator depending on the model but usually their all the same.Any questions let me know.
Apr 15, 2009 | Cecilware FMS-40 Deep Fryer
Want to change natural gas to propane
You need to change the regulator,gas valve and burner orfices and possibly the pilot.If you have a commercial fryer go to 3wire.com and you will find the part's you need.Any questions?
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Deep fryers
Jun 06, 2008 | Pitco Frialator SG14 Deep Fryer
Dean deep fryer
need to change from natural to propain sr42 g
Oct 08, 2007 | Frymaster Dean SR42G Deep Fryer
Kitchen Appliances - Others Logo
171 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
