Question about Franklin Industries FBC360D Beverage Cooler
Service for everstar wine coller model hdwc35
1 Related Answer
aviral_srms
Aviral Saxena
  • 1216 Answers
SOURCE: I have an everstar hdwc35,
It is a faulty thermostat not the control board An open thermostat defaults to a high value, so it does not shut off. If it was a bad compressor, or low in freon, it would not "get ice cold". If it is low on freon, the low pressure switch would not let it start up.
The defrost timer either runs normally (cycles on and off cold) or is in defrost mode (heater elements turn on to temporarily heat the freezer in order to remove frost). Anyway, It is not the defrost timer if it "gets icy cold".
Posted on Jul 31, 2011
Is it worth fixing an everstar wine cooler hdbc361d
Everstar Beverage Wine Cooler HDBC36ID not cooling
Ouch ... prior fixya thread on this model paints a pretty bad reliability picture...
Feb 15, 2018 | Furniture
Is there a manual for HDWC35, wine cellar?
Try Googling (brand)(HDWC35)(manual) without parens.
Jan 02, 2018 | Furniture
I'm replacing my starter relay, 3012-5a A1G7 Cubigel SA and overload and forgot which lead to connect it to.
Dale:
I'm currently researching a related question and found this image. It may be what you need.
Dennis
Feb 16, 2015 | Furniture
Everstar hdwc35
Do you still have your Franklin HDWC35 wine cooler?
Feb 08, 2014 | Furniture
NEEDED: manual for BC 112G wine cooler
Hello Ahanaples,
I understand that you are trying to locate a user manual for you Haier BC112G wine coller. I have located the manual on Haier.com the following link will take you to the page then you just have to click on the model of the unit that you have the first one at the top of the page.
http://www.haieramerica.com/en/support/modelsearch
Thank you for choosing FixYa.com
Justin Burnett
Mar 28, 2011 | Haier BC112G Wine Cooler
Model # HDWC35 Wine Cooler is not cooling at all.
Thermostat failure in those is very common. One quick test is to bypass the thermostat. And if it runs, you need to replace it.
Dec 12, 2010 | Avanti EWC28 28-Bottle Thermoelectric Wine...
Can manuals and parts be ordered for Everstar wine coolers, HDBC36iD is the model. Thanks, Dave
Im sorry franklen indust everstar wine systems are very hard to get parts for also the manual Not a very good unit eather according to reviews
Dec 09, 2009 | Refrigerators
Beverage/Wine cooler not cooling
call a local refrigeration repair service .
Jan 15, 2018 | Refrigerators
Leaking water from the back
make sure that the drain is connected properly at the back.
Make sure that the little drain pipe (usually clear hose) is sitting in the plastic shroud that sits on top of the compressor at the back of the fridge.
Apr 09, 2008 | Danby DWC310BL Wine Cooler
Franklin Industries FBC360D Beverage Cooler Logo
94 people viewed this question
Top Franklin Industries Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
