Question about Canon Pixma iP6600D InkJet Photo Printer
Waste ink absorber in cannon pixma iP6600D printer
How do i clean that printer only
5 Related Answers
Anonymous
  • 49 Answers
SOURCE: Canon printer PIXMA MP 150
I think this may work.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Posted on Jul 03, 2008
Anonymous
  • 81 Answers
SOURCE: Waste ink absorber is full. how to clear this
Canon recommend that you need to bring the printer to your local service provider, canon will not provide Joe Public with the replacement parts as consumables and even more importantly they will not provide the software to reset the error message.
From what I can see there is a hardware routine type fix for the problem,
Try
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or
Try
1. Turn off the printer. And disconnect the printer cable.
2. Press and HOLD the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button, the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
If this hardware routine type fix works it is at best merely a temporary fix, and needs to be repeated on a regular basis to keep the printers running. For a more permanent solution you need to combine the fix with the more complicated task of removing the pads and cleaning them. This is where the whole process can go disastrously wrong, the ink is permanent and will stain hands, clothes and furniture if it comes into contact with them. Check out the info on this website and on your own head be it
http://www.neilslade.com/Papers/inkjetstuff11.html
There are a number of websites which claim to provide the software fixes however using these is a kin to sailing in uncharted waters, it is your own choice however I would be hesitant to recommend it to anyone especially if there are a few government secrets on your hard disk
My advice is to find out how much your local service center will charge you to replace the ink absorber, then decide whether it is worth the expense. And when it comes time to change the printer remember canon's have ink absorbers which need to be changed by a service engineer
For more discussion on this problem (and many of the hard ware fixes plus a few links to the software reset providers) see the forums on
www.fixyourownprinter.com
Posted on Oct 05, 2009
Anonymous
  • 787 Answers
SOURCE: waste ink absorber is full can i replace or clean
Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
The waste ink absorber is on the back of printer.There is one cover who can open from the left side.You can replace it or clean it but the procedure is dirty and prepare yourself to get dirty.
Posted on Nov 09, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: waste ink absorber is almost full cannon pixma
Hi there
Ok hope you have good luck.
There no easy way the printers are been made this way so you take them to the shop, but if you are handy with your hands and know what you are doing then you will need to take all apart and take out the ink pads inside the printer and clean them up make sure they nice dry when put back in, then you are going to need a program that you can find on the internet it will be called waste reset tools, or your printer will not work even after you done the clean out.
I am not sure what canon you have so I cant tell you the tools you need for yours, i have got canon MP-Tools on my website if this is the one you need.
with this you can reset the waste ink tank before you do the clean out but remember in time you will need to clean out or it going to be a big mess of ink coming out your printer.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
Posted on Apr 25, 2010
How do I clean the printer waste ink absorber on my pixma ip6600D
You are looking at an aprox. 75% strip of your printer, the absorber sits at the bottom right had corner of the machine and it is a long drawn out procedure.
There are instructions for replacing and cleaning ink absorbers on You Tube and also instructions for resetting the printer. It is too involved and lengthy to try repeat here. Try looking at:-
http://www.youtube.com/watch?v=VVpjqBr7KjU
Jul 06, 2011 | Canon Pixma iP6600D InkJet Photo Printer
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
How do I clean the waste ink absorber on a cannon ip90
We are not advice to clean WASTE INK ABSORBER.
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
Cannon
CAN SOMEONE ADVISE ME WHERE TO FIND THE INK ABSORBOR SO I CAN CLEAN IT
Sep 16, 2008 | Canon PIXMA iP1600 Printer
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon Pixma iP90 waste ink absorber is full- HELP!!
Cannon Pixma iP90 waste ink absorber is full. The printer is not printing
Mar 10, 2008 | Canon PIXMA iP90 InkJet Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
533 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
