Question about Berkel 827E Gravity Feed Deli Meat Slicer
SOURCE: Globe Meat Slicer Model # 500
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Posted on Dec 24, 2008
SOURCE: The blade on this berkel 827e bogs down to a stop
most times the belt fill slip if you overload it and no they don't have oil holes
Posted on Apr 28, 2010
SOURCE: to sharpen the blade of my meat slicer
The stone that sharpens the back bevel is used for more time, but use grind for minimal amount of time, 30-40 seconds sounds extreme to me. The stone for the top surface of the blade is only pressed briefly to remove the slight burrs from sharpening on the back side of the blade.
Posted on May 22, 2010
First of all they have to be stainless , with out taking the hub out I guess you could bring the slicer to the hardware store and try serveral screws till you get the correct ones , I don't recall the size , maybe someone else on here will have the size for you
Posted on Dec 13, 2011
Dec 23, 2016 | Rival Food Processors
Feb 08, 2016 | Kitchen Appliances - Others
Mar 26, 2014 | GOURMET LIVING Shopko Meat Slicer NO...
Feb 19, 2014 | Weston Meat Slicer
Dec 22, 2013 | Kitchen Appliances - Others
Oct 09, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
May 08, 2008 | Food Processors
62 people viewed this question
