SOURCE: Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
SOURCE: how do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
Posted on Aug 23, 2010
SOURCE: Pool pump has been working
Hello
Check the pump impeller by shuting off pump taking out strainer and putting your fingers in to get any debris out.
After you put strainer back in put a bucket of water in collection basket to prime pump.
Also check your o ring on the strainer lid.If its cracked or worn the pump will not prime,but continue to **** air.
Also be sure your in filter mode before starting the pump up.You may need to lossen strainer lid a little to bleed ot air until water starts to flow again.
Possible bad o ring on stainer or impeller on pump is bad.
You may want to try putting the filter in backwash or drain mode and blow out any air also.
Posted on Jun 16, 2011
Jul 12, 2014 | Pool & Spa
Jun 27, 2014 | AO Smith Pool & Spa
Jun 06, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
May 23, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
Feb 16, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Jun 06, 2009 | Intex Automatic Salt Water System for ...
May 25, 2009 | Jandy PHP High Head Pump 2 HP Up rated
Feb 18, 2009 | Pentair 1.0 Hp Whisperflo Pump
Aug 27, 2008 | Intex 2500 Gallon Sand N Sun Pool...
