Question about Science & Laboratory
Contol panel won't turn on enigma 8 - Science & Laboratory
Ruth Strong
My control panel lights up for a few seconds then goes off. Try a second time and won't light up at all. Give it a day being left alone and same thing happens except for one time when it went through a cycle. Checked the fuses at the back in a fuse tester device and both seem okay. Seems to indicate the connection of the fuse is at fault as erratic. Any ideas how to fix this.
Posted on Aug 16, 2021
maxxratt
  • 25 Answers
More info needed. What happened before it wouldn\'t turn on. Is it plugged in ( stupid question)? Does the outlet you have it plugged into supply the necessary power? What condition are the fuses in?
Posted on Oct 29, 2014
Enigma 8 Autoclave. Why does it display "Error code E13"?
hi, hopefully this will point you in the right direction.
https://excelhealthcare.co.uk/faqs/
Regards
Rob
My enigma autoclave isn't starting. There is no error message on the screen. It just beeps 3 times and does nothing?
I know nothing about Enigma but this is typical of PC problems with memory. If there is a Keyboard, try getting into Bios by restarting and pressing F2 and Del keys alternately on turn on. This gets you into most computer Bios. When there, look for Memory/RAM to see if it is seeing any. Try "Reset to defaults" as a last resort.
Try to get the manual and look for "Trouble Shooting" section. If it has info on memory installation (for example, adding or replacing, read carefully.
If you have a techie guy there, think about opening up the Enigma to get to the main board (mother board) and removing the RAM module(s). If you can have them tested, do so. If not, clean them with a dry clean toothbrush, blow out(or vac) the main board socket the RAM came out of (be sure Enigma is plugged in and off and not too much vacuuming as it builds up static). And if there are more than one RAM, plug in only 1 or reverse the slots or use other slots if there are any. Try all combinations. Power off between each removal/insertion. Be careful and gentile but firm. Be careful of static electricity. Any little "Snap" you hear from touching some thing is a hazard to electronics, so keep in touch with the machine to stay grounded. Hold the RAM, use that hand to touch the Enigma 1st without touching the RAM to the Enigma and then proceed. That grounds you and by default, the RAM safely. Peep the Enigma plugged in but turned off except when testing.
My enigma 8 autoclave is showing an error code of E21 and this does not appear n my user manual...help
This really comes under the category of laboratory equipment, not digital cameras, I'm afraid.
Aug 10, 2016 • Cameras
Charges related to Spy Hunter and Reg Hunter
Go Pc Pro Best Online Computer Tech Support Provider
Need installation drivers for enigma 3.1, lost disk
Here's a link for a driver. Just need to put in a verification code and then click download. Might have to click on a thing with a blue arrow pointing down that pops up on the top of the screen that asks you to download the file. If that happens you might have to restart the download.
http://download.driverguide.com/driver/Enigma+1.3/Digital+Dream/d362827.html
Could the front contol panel be bad if my T.V. dont turn on
More likely no power to set; either no AC from plug outlet, or internal fuse in power supply.
Science & Laboratory Logo
Top Science & Laboratory Experts
ray gallant
Don A
Don A
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
