Watches Logo
A
Anonymous Posted on May 19, 2014
ADH2771 Hot to set time on this watch
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
2answers
Dead Watch - Citizen Eco-Drive Skyhawk Titanium
replace it.or service it with authorised center...if ur under warrenty period..because its a sensitive one..
Sep 24, 2008 • Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Can't set juicy watch
pull crown out then you can turn to correct time then push crown back in
I took a shower with my kc3771 watch in the bathroom. I didnt even get it wet but a little steam got. How do i open the case to dry the steam.
Don't open it. Take it to a watchmaker and have him/her dry it out. If you refuse to do that then pull the stem out and set it in a sunny window for a few days or use a hair drier. I always know what time it is in the shower without a watch, when the hot water runs out, it's time to get out!
2helpful
How do i set my casio databank to beep every hour
Hello I was in the same problem the last 5 hours causea icant find my owner manual, i put a new battery on my "oldie" but great watch and pusshin and seting i got it....
You have to put in "alarm mode", remember you have to push BOTON MODE. Then you will be at "stand by mode", "data bank(phone) mode", "world time mode", "alarm mode" "chrono mode", and set (analog watch) mode"
then you are in "alarm mode" then push "REV and FWD BOTONS" at the same time, one time, or two times or three times, until the "beep icon and bell icon" are in ON mode
Good look
sareg@hot....
5helpful
2answers
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 • Watches
5helpful
6answers
Anyone know how to set time on a NY-1385 watch?
First, go to the time mode which displays week day, seconds and timeas opposed to calendar, seconds and time. To do so, touch and hold upper left sensor until the watch beeps. Then use the upper right button to switch to the proper time mode. Then touch and hold lower right sensor. This will send the watch into settings mode.
May 03, 2010 • Watches
1helpful
I need to set the time on my g-shock 330a watch
Hi, mate. Do not know how it's going in Afghanistan right now, but I hated every single bit in that country 28 years ago (Russian invasion).
Unfortunately I was in service in Soviet Army, so, we would be shooting each other if you were there at that time.
Right now I'm very happy, 'coz I was fortunate enough to escape from Soviet Union 20 years ago and find my refuge in England.
Anyway - deepest respect to the guys servicing their own homeland in such a hot spots.
OK, back to business:
To find out the proper settings for your watch follow this link:
http://world.casio.com/wat/download/en/manual/
Submit requested details and downlosd latest manual.
Rate me, please.
Top Adidas Watches Experts
NOEL
NOEL
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Adidas Watch Expert? Answer questions, earn points and help others
