Question about Brother MFC7820 ALL IN ONE LASER PRINTER Refurbished Mfr P/N MF
I have Brother MFC 7820N printer. It has a loud clicking sound on the left rear end and paper will not feed, sometimes the first page will print and no paper message will be shown? Can you please help
Posted by SAIMA SIDDIQUI on
Andrew Henderson
    Sergeant:
  • Brother Expert
  • 394 Answers
It sounds like a displaced drive gear in the gear chain to the fuser. If you remove the covers and the fuser unit you should be able to manually turn the gears to check for jams or slips. Make sure all ther gears are correctly seated and no missing teeth.
Posted on Jun 29, 2014
5 Related Answers
Anonymous
SOURCE: back cover open error message MFC 7820N
Reseat inner rear paper guide to allow sensor to home correctly
Posted on Mar 09, 2009
Anonymous
SOURCE: black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Posted on May 15, 2009
fabjoe
SOURCE: Brother MFC-7820N Toner Problem
Open the cover, press Options and then *00.
Posted on May 22, 2009
Anonymous
  • 86 Answers
SOURCE: BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Posted on Jun 15, 2009
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Posted on Feb 25, 2010
HOW TO TAKE BROTHER PRINTER OFF OF MANUAL FEED OPTION
Hi there!
The message that ask you to manually feed the paper will appear if you have recently printed on a different type of media.
Does this happen from only one application like Microsoft Word? If it does try printing a test page or a document from other application like Notepad or Wordpad.
If the same issue occurs go to the Printers folder (under control panel) then right click on your Brother printer icon, left click on Properties, click on Printing Preferences and make sure that Tray 1 is selected for the tray, Plain paper for paper type. If changes have been made make sure to click on the apply button to apply the changes.
If it only happens to one application like Microsoft Word. Click on File ( or the orb icon on the upper left hand corner) then Print, then Print again click on Printing Preferences and make sure Tray 1 is selected and Plain Paper.
Hope this helps! Thanks
Jun 09, 2011 | Brother MFC-7820N Laser Printer
My Brother MFC-7820N has a paper jam problem that seems to be related to it's picking up an additional sheet of paper and when the first sheet completes it's print pass, the second is midway and the...
most paper has a smooth side and a little less smooth side, try flipping the paper. in the pack use the top side as the printing side when u load. try a different brand of paper could easily correct the problem,
some feed trays work best when nearly full also, try half full etc.
Oct 10, 2010 | Brother MFC-7820N Laser Printer
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 07, 2010 | Brother MFC-7820N Laser Printer
How do I use manual feed on the brother mfc 7820N printer/fax/copier?
The manual feed slot located in the front of the machine above the paper tray.
  1. Slide the gray paper guides to fit the size of the paper
  2. Using both hands put the paper (side to be printed, face up) in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the Brother machine feed the paper in a short distance.
  3. You must then go to the application that you want to print to the paper and use that application's paper settings to set the paper size, orientation, font, style, etc
  4. Good luck trying...
May 20, 2010 | Office Equipment & Supplies
PRINT IS SLANTED ON PAGE
Looks like a problem with the paper feed. The paper or the paper feeder is slightly off line, check this
luciana44
Jan 19, 2010 | Brother MFC-7820N Laser Printer
The paper deck is full but wont print. display reads "no paper feed"
The paper feed wheel (located in the front just inside where the paper tray goes) could be missing, broken, or the clutch that drives it could be bad. I'm not sure this will work but try to look at the wheel with the tray removed, and print a page, see if it rolls.
Dec 02, 2009 | Brother MFC-7820N Printer
FEEDING PROBLEMS FROM PAPER TRAY
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist PhillyCopiers.com 215 364 3774
Apr 19, 2009 | Brother MFC-7820N Laser Printer
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Continual paper jams in rear of printer
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
Jan 03, 2009 | Brother MFC-7820N Printer
The 7820N prints double-sided manually using the drivers. From Windows, select File / Print. On the pop-up window, click on Preferences, select the Advanced tab, click on the A/B pages icon, and select Manual Duplex. "OK" your way out. When you print, you'll first confirm to print one side of all pages. Then follow the instructions that appear.
Jan 25, 2007 | Brother MFC-7820N Laser Printer
Brother MFC7820 ALL IN ONE LASER PRINTER Refurbished Mfr P/N MF Logo
69 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
