Hitachi AC stops working after Red Light glows
Nothing works ac stops working please help
Posted by Pankaj Jain on
W.L.
  • 2,509 Answers
No model number, no error codes!
check the obvious like is condensate water getting released, is anything blocked including any filters, the inlet, the outlet, or any hoses. Is power OK.
Posted on May 19, 2014
5 Related Answers
Anonymous
SOURCE: Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Posted on Oct 02, 2008
seth veloso
  • 334 Answers
SOURCE: Need user manual for hitachi logicool window ac
check out this link for the timer:
http://www.logicool-ac.com/pdf/015%20-%207%20Day%20Timer%20Operation.pdf
check out this link for the manual
http://www.logicool-ac.com/tech_downloads.html
Posted on Jun 11, 2009
Anonymous
  • 534 Answers
SOURCE: amana Ac compressor won't come on. Heat works fine.
would suggest replacing the compressor capacitor first before going any further. The capacitor aids in the initial start up of the compressor and if it is bad the compressor will not start. The capacitor is located in the area behind the control switches and is usually gray in color and round. They may be oval and silver also. For this type unit I think the capacitor is a dual capacitor which means it also runs the fan. Note that the compressor side of the capacitor can be out and the fan still run. So before I would think about replacing the compressor I would replace the capacitor which is about 30 to 40 U.S.D.
Good luck hope this helped
Dave
Posted on Mar 30, 2010
Testimonial: "great advise god bless"
Dennis Boxerman
  • 1305 Answers
SOURCE: red blinking and ac not working
If the power "flickers" and unit fails but will restart once the breaker is reset, this sounds absolutley normal. It is a safety device that keeps the unit from burning up things due to improper power being supplied. As long as resetting puts it back into service with no issues, don't worry about it.
Posted on May 14, 2010
Anonymous
SOURCE: I need the user manual - hitachi logicool i window ac with remote
what are the functions of remote control for hitachi window ac logicool
Posted on May 10, 2011
I just moved my Hitachi 42EDT41A and now it won't turn on. I don't even get the red standby light. It was working fine before.
Check whether the AC is present to TV. Try it by an other AC outlet. If it has been working fine, there should be no problem at all.
Sep 13, 2013 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
AC power light blinks but not starts
The outside unit has a problem. Have it tested.
May 05, 2017 | Hitachi Heating & Cooling
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
RED LIGHT BLINKING IN HITACHI ICLEAN AC.. WHAT TO DO?
I was told the same thing that Dennis has posted by the guy who came to service the AC. So I think, it is ok as long as it blinks 9 times in a row and then repeats it after a brief pause.
Jun 08, 2012 | Heating & Cooling
Hitachi split ac ace cutout how to go to standby mode
Its very simple to remove that red light glowing on the AC, just switch-off your AC with your remote, but don't turn off the switch that resides with in the plug, remove filters wash gently and dry under shade and place them again in the AC, now keep it without turning-off the switch for 30-60minutes this is called stand by mode. Now take the remote open the panel and press the button that is situated in 4th row and 3rd column. By doing this the red light will be turned off and enjoy your AC.
Apr 17, 2012 | Heating & Cooling
Hitachi ACE follow me red filter light is always on
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
Apr 03, 2012 | Hitachi Heating & Cooling
My AC unit is not working ,blower is not coming on
your blower motor failed and you need to replace it
Aug 20, 2009 | 1990 Mercedes-Benz 190
1996 Avalon AC stops working on long trips
over heating of the condenser(fans not working) or a blockage in the system maybe expansion valve
Jul 03, 2009 | 1996 Toyota Avalon
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
