Question about Locks & Locksmithing
Safewell electronic safe instructions
I have a safewell 23D Electronic safe, I cant remeber the password and but am unable to reset the password using the red button then putting in a new 3-8 didgit code follwed by the B, its just double beeps which means its not acepted , the only way I can lock it is if I take out the batteries and use the overide key to lock and unlock, HELP please
    Top Expert:
  • Locks & Lock... Master
  • 1,533 Answers
6ya staff
SOURCE:
Anonymous
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
Anonymous
SOURCE: i have a safewell electronic safe and no keys and
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or [email protected]
Posted on Sep 02, 2009
Anonymous
  • 124 Answers
SOURCE: i forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell [email protected]
Good luck
Posted on Sep 14, 2009
kswoolf
SOURCE: I purchased a Grafter Electronic
Inside the door on the hinge side is a button press and release this and release this and you will hear two beeps.
Now input your code of between 3 and 8 numbers and confirm by pressing either A or B.
Hope this helps.
Posted on Feb 07, 2011
pctech1
Jeremy Moore
  • 1940 Answers
SOURCE: kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Feb 21, 2011
I have a safewell electronic safe with no keys. Now safe will not unlock using pin code. Need to unlock safe to change the code!!
Contact manufacturer to request assistance.
http://www.safesworld.com/contact-us/
Complete form online to request assistance, or call.
SAFEWELL GROUP HOLDINGS LTD
SAFEWELL EQUIPMENT LTD
No.28 Pushun Road,Xiaogang Equipment Industrial Zone,Beilun,Ningbo, 315800
Tel: 86 574 27902999 - 6839 / FAX 86 574 27902987
Email: [email protected]
Web: http://safesworld.com
Aug 29, 2018 | The Computers & Internet
Have a safewell electronic system safe ex2007126498 want to open it lost key and forgot the password
won't work.
ELECTRONIC SAFES
electronic keypad -159B. (These numbers are preset. You should change the codeicon1.png as soon
knob so you can turn it and retract the locking bolts.
Apr 22, 2014 | Computers & Internet
I hv a safewell safe. i locked the emergency key before setting my personal key inside the safe. how to open the safe now?
You'll most likely need help from a locksmith. Basically, the lock can be picked, to get the safe open. There might also be a factory pre-set code.
Aug 16, 2011 | Locks & Locksmithing
Change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Nov 22, 2009 | Safe International Digital Electronic Safe...
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
Good luck
Sep 14, 2009 | Locks & Locksmithing
I have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
Jul 26, 2009 | Locks & Locksmithing
Locks & Locksmithing Logo
250 people viewed this question
Top Locks & Locksmithing Experts
john h
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
