HP Officejet 5610 All-In-One InkJet Printer Logo
A
Anonymous Posted on May 19, 2014
Error: 0xd0620130 Reset power. - HP Officejet 5610 All-In-One InkJet Printer
Nikesh Mehta
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Jun 18, 2014
Nikesh Mehta
Contributor
Level 1:
Welcome Back:
Answers
Questions
Helped
6789
Points
11
Carteage pcb change
3 Related Answers
Anonymous
  • Posted on Apr 27, 2011
SOURCE: All lights are flashing and
Hope this helps, you need to Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Anonymous
  • 8637 Answers
  • Posted on Jan 25, 2009
SOURCE: Error: 0xd0620130 Reset power.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
puertobori
  • 7733 Answers
  • Posted on Dec 20, 2010
SOURCE: error 0xd0620130 reset power
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  5. Wait 60 seconds.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.
Post / thumbs / testimonial are welcome!
All lights are flashing and it says Error 0xd0620130 reset power. I have unplugged all lines and even uninstalled it then reinstalled the software. After that it was fine till I tried to print...
  5. Wait 60 seconds.
Why Error: 0xd0620130 in HP Officejet 5610 comes, pl. advise
Power reset.
Wait 60 seconds.
Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Hope this helps.
If this helps you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well.
Thank you.
1helpful
Officejet 5610 All-In-One InkJet Printer: error 0xd0620130 reset power...
Please try the below resetting steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Rizwan
Error 0xc18a0401
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code not in this but it some times clean the error uo with this type of error number you can gave it a go Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2helpful
Error. Oxc18a0401 displayed?
Hi
This works with lots of the same codes
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. Error 0xc18a0201 with HP printers Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
1helpful
Ink system failure HP PhotosmartD7160
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Printer gets error 0xc18a0106
Reset the product:
5. Wait 60 seconds.
1helpful
3helpful
4answers
ERROR MESSAGE 0xd0620130 APPEARS
hi adonscott.
This approach solved the problem temporarily, after a while, it re-appears.
do you have any other sugestions?
thanks.
lavender
1helpful
2answers
sir i hve printer of hp 5610 all in one error come error no 0xd0620130 and all light blink. so pls ive me solutions
k24674
Grand Canyon Tech
Grand Canyon Tech
