Question about Sharp AR-5316 Advanced Digital Imager Copier
My Sharp Ar 5620 sl is showing F2 or 2F Error what will i do to solve the problem
Posted by Muhammad Ilyas... on
Poppa Maddo
    Sergeant:
  • 372 Answers
You call Sharp Service. There is no way you could fix the problem even if you were told what the codes mean.
You can find that out when the Technician calls to fix it and give you a either a "guesstimate" or a formal written quotation. Either way you will either have to pay a call-out fee, or if you transport it to them, an inspection and quote preparation fee.
Nothing for nothing in this world......sorry !
Poppa
Posted on May 19, 2014
5 Related Answers
Anthony Karuku
  • 268 Answers
SOURCE: ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Posted on Nov 24, 2009
Chuck Clark
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
san3409jl
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
Anthony Karuku
  • 268 Answers
SOURCE: Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Posted on Feb 12, 2010
hamidamini20
SOURCE: i have a sharp photocopier AR-5316 flashing error
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Posted on Jun 06, 2011
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
Can toner for sharp AR-5620235ft work in a sharp AR-5516 021ft please help? give me some ideas people ?
Yes. It is compatible. But, before switch it ON; after the replacement, keep a distance from that device. It will be safe for U.
Sep 07, 2016 | Sharp Office Equipment & Supplies
I need software driver SHARP AR5620 SL
Try Glary utilities (free) I think I noticed they have a way to update drivers
Mar 11, 2015 | Sharp Office Equipment & Supplies
WHAT IS THE PROBLEM WITH SHARP AR-5620 SL WITH ERROR CODE L1
Mirror base feed trouble
The mirror home position (MHPS)
does not turn off though the feed
operation is completed during
mirror initial operation after turning
on the power.
does not turn off during shading
operation.
does not turn on when the mirror
base is returned for the specified
time after copy feed is started and
SPF scanning position shift is
performed.
Jun 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
PROBLEM WITH SHARP AR-5620 WITH ERROR CODE CH
Hello Sir.
I have trouble with my Sharp AR-5620V copier.
when i switch on my copier it has sound pollution like broken wheel in inner side and not printing
Feb 17, 2014 | Office Equipment & Supplies
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
Apr 15, 2013 | Sharp AR-M237 Copier
U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
May 20, 2009 | Sharp Office Equipment & Supplies
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
1,165 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
