Using the volume control buttons on the television itself (not the remote) turn the volume all the way down to 0. Using the volume controls on the Digital box itself. Turn up the volume until it is at the maximum. Using the television's volume controls again; raise the volume to a comfortable level. If you are still experiencing the audio problems on this television, it is possible there is a loose connection on the television.
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Chances are that one of the volume buttons (either on the TV itself or on the remote) is stuck. You'll be able to know if it's the remote by taking out its batteries and trying the same process. If the issue persists, see if the volume down button on the TV is stuck and can be freed.
If it has on the steering wheel controls, they are bad. They use a carbon type impregnated rubber and being in hot and cold can cause this. IT could also be the clock spring in the steering column or if none of those apply then it is radio itself.
Hi, It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level. Press volume down button on tv front and check is it working properly. Let me know to find out further info to solve the issue. Thanks.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
