Question about Supersonic IKONVERT Digital TV Converter Box
Remote won't work. LED screen reads boot - Supersonic IKONVERT Digital TV Converter Box
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
Sony vgn screen backlight won't come on
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 07, 2012 | Computers & Internet
My toshiba satellite l505d-s5986 has black screen and won't boot but fan is working
Dec 01, 2012 | Computers & Internet
Magnavox 37MF331D 37 inch won't power on with no led light
check the power supply board for swollen filter capacitors
Oct 15, 2012 | Televison & Video
My screen dont light on my aspire 7250
I have just fixed an Aspire 7250 with following symptoms: Only blue Power LED or battery charge LED come on, fan spins, no backlight, no video either on internal screen or VGA output.
Problem solved desolderig BIOS flash chip (W25Q16) and flashing BIOS 1.10 with an universal programmer.
Aug 06, 2012 | Acer Computers & Internet
Hi i am trying to change the screen size on av2 and 3 but it wont work the aspect button
Check the remote control for its infrared emission from infrared LED at its front. Do not assume that the remote control is OK, as the indicator LED on it lights up. It is only an indication that the remote control circuit accepts the keystrokes.
Just visit this site [Eectro-help]. You will get all details about how to check a remote control. All details are given there. Pull up older posts there. Search for it either by Yahoo or Google.
Make sure that the remote control is correct in all respect first. I assumes that the remote control you possess now is the original remote control of the set. Not a universal one. If it is a universal one, this type of fault can occur, because all universal remote controls won't respond to some functions.
May 09, 2012 | Panasonic N2qayb000184 Remote Control
Screen won't work
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 26, 2012 | OQO Computers & Internet
Toshiba l355d - s7815 won't boot and screen doesn't light up
From your description you have a motherboard issue, the only way to rectify this, it must be replaced.
Mar 26, 2012 | Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
I got a Sony CMT-NEZ30 from a friend and I don't
Get the manual , which a simple search engine query for "sony CMT-NEZ30 remote" would have led immediately to...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CMTNEZ30
As far as remote failures go...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 28, 2011 | Sony CMT-NEZ30 Shelf System
Supersonic IKONVERT Digital TV Converter Box Logo
107 people viewed this question
Top Supersonic Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Kardoc
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
