Question about Timex T309TT Clock Radio
Cancel alarm settings
How do you turn the alarms off. I don't want them on at all. the manual only shows you how to set the alarms
Posted by mazy on
Anonymous
  • 3 Answers
Push the buzzer button once, or until the word "buzzer" shuts off in the display.
Posted on Dec 15, 2007
My 97 Honda accord se wont turn over, and car alarm keeps going off
the alarm is the fault refer to your alarm manual to disable it, if you don't know about this unit it is best to seek help from someone qualified and available to look at it for you, it seems as if your alarm is set, most alarms have a starter disable function and the alarm going off is an indication that it is set.
May 18, 2012 | 1997 Honda Accord
Timex expedition wr100m alarm
TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
May 04, 2012 | Timex Expedition Watches
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
I have lost the operating manual for a technika DAB 109 Radio
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Mar 07, 2010 | Audio Players & Recorders
Ge 7-4901a
Push the SET WAKE/TIME button on the far right of all the buttons - it's the button closest to the CD player. Push it until the 1 or 2 show up on the display - whichever one you want to use. The push the CD player's forward button - the one with the two right-facing arrows - until the time you want to wake up shows up in the display. That's it. To turn the alarm off, push the WAKE CANCEL button, below the set wake/time button, the push the 1 or 2 button, depending on which alarm you want to turn off. The display will show OFF in the alarm you chose.
Jul 24, 2008 | GE 74801 Clock Radio
T307S How to deactivate the alarms
Timex T307S
I lost my manual also so had to resort to relentless trial and error.
The problem with the alarm is that it is too easy to turn it on.
The 1 and 2 buttons on top of the unit with the alarm clock symbol turn each alarm on or off. Your only cue is on the display in the top line of the display which will have a bell followed by “RADIO” or “SOUNDS”, if the alarm is armed. If you see this symbol and want to disarm the alarm, press the 1 or 2 alarm button according to which alarm was on the display. It’s just as easy to turn the alarm back on either deliberately or accidently
Enter Alarm Setting mode by holding the 1 or 2 alarm button for about 2 seconds.
Display will flash – in this mode you will be able to do the following
Date Set Button – changes between Everyday/Mon-Fri/Sat-Sun
Arrow Buttons – adjust the time setting
Alarm 1 (Radio):
Mode Button – changes between AM/FM1/FM2
1-6 Buttons -- changes between stations
Alarm 2 (Sounds):
Mode Button – changes between SD1/SD2/SD3/SD4/Buzzer
If you don’t change any settings for about 5 seconds the unit exits the alarm setting mode.
Timex already has your money so I guess they are not motivated to publish their manual.
Feb 08, 2008 | Timex (T307S) Clock Radio
HOW DO I SET THE TIME?
Wildbill,
My wife has the AudioPhase SPR1 AM/FM 2 AAA portable sports type music player. There is no pdf manual available on internet yet - I will scan and post when I get time. The paper manual says:
To set the Clock:
1. Turn unit off.
2. Press MEMORY once: the clock will start flashing.
3. Press DOWN/MIN to set the minutes, press UP/HOUR to set hour.
4. Press MEMORY again to complete time set.
5. There is always an AM/PM indicator on the LCD display to indicate DAY or NIGHTTIME or night.
To Set Alarm:
1. Turn unit off
2. Press ALARM once: the alarm will start flashing.
4. When alarm time setting is complete press MEMORY 3 times.
5. The alarm setting is completed.
6. Now alarm standby is ON. ALARM indicator will now show on the display.
--> Alarm will only make a noise throught the headphones. When it goes off cancel it by pressing ALARM.
Canceling ALARM standy by.
1. Turn unit off.
2. Press ALARM twice.
3. Now ALARM standby is off.
Radio:
To Seek press UP/HOUR or DOWN/MIN to click throught the frequency or press and hold to seek.
Oct 27, 2007 | Griffin Technology SPR1 AM/FM Radio
Timex T309TT Clock Radio Logo
182 people viewed this question
Top Timex Audio Players & Recorders Experts
Janelle Schoonover
Janelle Schoonover
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
