Question about Samsung HLR5667W 56" Rear Projection HDTV
What causes white and pink bars on screen - Samsung HLR5667W 56" Rear Projection HDTV
White color in LCD monitor appears as pink anywhere ! but sometimes it back to white color truely.
This can be a common problem with laptop screen when white goes pink. This is caused by a faulty cable that runs from the laptop motherboard to the inverter just under the screen.
The cable becomes stretched after a while by movement of the laptop lid which pulls a pin from the cable.
What i suggest you do is take the laptop to PC repair store and have them fit a new video cable or order a replacement video cable from eBay and replace the cable yourself.
Don't be fooled by the preconception that its a bad CCFL bulb (backlight) as this is not the case.
Regards
Jun 25, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
There is a black line and see through pink bar on my monitor
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
also check you warenty its usually 3 years
Apr 12, 2010 | Dell 1702FP UltraSharp 17" TFT LCD...
Asus x83v monitor has a red flickering bar across the lower part of the lcd it is as thick as the task bar thats why i have to place the task bar on the top, its like a static flickering red to pink and...
The display hardware is damaged. Most likely you will need to replace your screen. In rare instances, this can be caused by a loose ribbon connector from the display to the display adapter board.
Mar 29, 2010 | ASUS X83Vm-X1 Notebook
I have a LCD tv and I have bars that consist of pink and white dots and a solid pink line on the right half of the screen. What is it and what can I do to fix it. My tv is a samsung model LN-T4681F
Regarding this issue you might have an issue with your analog video board, or digital video board, probably one of these parts is not sending exact image that it's receiving, You might want to check with a tech that can check the TV physically. Hope i could be on assistance.
Mar 16, 2010 | Televison & Video
My acer X193w+ screen turns pink. What is causing
laurie515, Gee, I hope it's a 'pretty pink' colour. Do you really mean that What was once WHITE or VERY Lite GRAY is now appearing pink??? Laurie515 you must tell us more. How old is this unit? 4-6 yrs? I suspect that the "Cold-Cathode-Fluorescent-Tubes" that are hanging on the rear of the LCD glass panel and provide white light, have over time, now become tired out. YOU WILL NOT FIX IT!! IT WILL ONLY GET WORSE. Here are some options. 1. Trade in for new if yours is >4yrs old. 2. Check for swapout program with ACER? This is only a dim Maybe thing. You send them yours +$50-$100 and they return a refurbished unit. 3. Find local TV/Monitor Repair shop that knows all about LCD monitor repair. there are also guys on fixya that do LCD refurbishing (new ccf tubes/inverter/smps) Do some web searches on LCD monitor failures and also visit youtube for vid clips of monitor disassembly if you want to see the insides of a typical LCD monitor.
Bye for now. I'm louie12fix on fixya or [email protected] aol.com
Sep 24, 2009 | Acer X193W LCD Monitor
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I hooked up this moniter turned on the power and nothimg black
My Dell monitor is showing odd splotches of colored bars.....turquoise bars and pink bars. What is causing this?
Apr 21, 2009 | Computers & Internet
Optio S40 white objects are pink
Sounds as though the white balance is off, check your manual on how to alter the white balance to manual - then change it back to auto. It should fix it.
Feb 12, 2009 | Pentax Optio S50 Digital Camera
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Samsung HLR5667W 56" Rear Projection HDTV Logo
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
