If the computer not logged on to the domiain in 2 months or more the computer has to be readded to the domain.
Windows uses DNS to find the domain controller. Enter the domain controller's IP address as the primary DNS server on the computer that needs to join the domain. Ping the domain controller's IP to make sure it is accessible. If you can't ping it, check firewalls and routing until you can ping it. The clock on the joining computer must be within 5 minutes of the time on the domain controller. Use the DNS name for the domain instead of the NetBIOS name. (The DNS name is the one with the dot in it) You should be able to join the domain now.
If you still have a problem, I found that IPv6 can prevent the joining of a domain. If it is the problem, unchecking the IPv6 protocol in your network adapter properties will take care of it.
Check your network
SOURCE: windows cannot connect domain either domain controller is down or
The resolution and workaround to solve the error is as below.
This should solve the unable to logon to domain error, without changing or losing the user profiles on AD.
