Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
What is the height specification on this dishwasher
1helpful
2answers
What is the installation specifications on this particular model? Dimensions?
Patty,
Most dishwashers need an opening that is a minimum of 24" wide and 34" to 35" in height. Normally, you can adjust legs on the unit to adjust for the height you need, but you have no adjustment for the width. Hope this helps!
2answers
How to adjust height
there are usually 4 feet at the bottom that are adjustable by a couple of centimeters to bring it to right height & level it.
1helpful
What are the dimensions of the MDB7100AWB
Hi Bridget, good day! You can check the product and other technical specifications of your Maytag Dishwasher on the link below:
http://www.maytag.com/-[MDB7100AWB]-1102605/MDB7100AWB/
Also, for your quick reference, here are the dimension details:
Width: 23 7/8 Depth: 27
Height: 35 1/4
You can also check this link for more specific measurement details:
http://www.maytag.com/digitalassets/MDB7100AWB/Dimension%20Guide_EN.pdf
What is width depth height specs
Good Morning Friend,
I see that you are looking for the width, depth, and height of the Frigidaire dishwasher, model# FDB636GF. The measurements are as follows:
Width: 23 7/8"
Depth: 24 1/4"
Height: 33 3/4"
Hope this is helpful.
-Best regards-
WP
1helpful
What are the exact cabinet dimensions of a Roper dishwasher, model #RUD3000? Thank you!
The manufacturer specified cabinet dimensions for this model are:
Total width: 23 7/8" / 606mm
Total height: 33 7/8" / 860mm
Total depth (front to back): 24" / 610mm
If you need any further specifications for this model, please reply within this solution.
Regards,
BElectric
2answers
Door wont close on fdf780 dishwasher
Check the shelf height. If your machine has an adjustable shelf (like mine), then if it slips out of position on one side, the door will not shut.
Try lifting up the shelf.
14helpful
3answers
Height for dishwasher is only 33.5 inches
we found a fridgidare dishwasher the had a range of 32.5-34 model number FDB2410HIC1 try it, it saved us from having to do alot of tile cutting
Jan 05, 2009 • Dishwashers
Top Kenmore Dishwashers Experts
vince
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
