Question about Tomtom GO GPS
A red circle with a white cross appears on start up that is as far as it goes. Unable to get to start menu, have tried restting amd loading updates.
PART NO. 4EX0.001.01
5 Related Answers
Anonymous
SOURCE: TomTom GO 720 - flashing red circle with white cross on screen
Hi, I am back, just got the problem solved, I called their tech support at no charge (866-486-6866, Glen) , really good service.
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Hope this helps
Aldo
Posted on Dec 03, 2007
Anonymous
SOURCE: GO 910 Cannot remove flashing white cross in red circle
Same here today. Had to replace all the files with those I copied and burnt to a backup CD when I first connected the ONE. If I try just a map update through Home (not an application update) then I get a "No Maps" message after startup. I'll bet dozens of perfectly good units are being replaced by retailers everywhere. I am now going to seek an explanation from TomTom. It may just be that the current updates are buggy or corrupted. At least I had the sense to back everything up before I tried to update the thing so I can quickly get going again. Spent about three hours so far faffing about with this "plug and play with yourself" little marvel. Bah!
Posted on Mar 03, 2008
Anonymous
SOURCE: 730T - tomtom home hangs when checking for updates - mac
Hi - have had the same problem - if you look on the tomtom website and support they have a list and one is flashing red cross. You need to follow the steps to format the tomtom. I did this and it worked and it included the update. i havent reconnected since i have it working now. I think its a software problem with HOME. Make sure you do a back up on home and make sure you follow step by step. close HOME before you start to reformat and also in the preferences turn off the automatically connect to home when you plug into your computer or it keeps flashing up on the screen to correct. the only solution is to format it. i bought mine two days ago and the first one stuffed up so took it back for a replacement. this one worked when i turned it on but turned out the flashing cross appeared when connected to computer (i have a mac). good luck
Posted on Jan 22, 2009
Anonymous
  • 515 Answers
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
Posted on Jan 27, 2009
Anonymous
  • 515 Answers
SOURCE: device frozen with blinking x in red circle on screen
Posted on Apr 13, 2009
My laptop has lost sound showing no speakers or headphones are plugged in red circle white cross
My laptop does that sometimes and a restart fixes the problem - so far!
If restarting doesn't fix it you need to open the device manager and if audio devices are in the list try and troubleshoot them. If not in the list it is probably a hardware problem.
Feb 20, 2018 | Red Computers & Internet
TomTomGO
youll need to reload the firmware
that should fx it
Aug 28, 2008 | Tomtom GO 910 GPS Receiver
that usually appears when closing the unit down, can you provide more information
May 18, 2014 | Tomtom GO GPS
Red and white cross appears on screen on satnav
cross indicates software problems or lack of software
Feb 17, 2013 | Tomtom GPS
White cross in red circle on the tomtom screen
hi. i suggest to try a soft reset first. go tomtom.com select support search for reset select softreset select your device do as told when this is not enough search in tomtom for start up and read wht to do.
Feb 21, 2010 | Tomtom One XL GPS Receiver
Jan 06, 2008 | Tomtom ONE GPS Receiver
Hope this helps
Aldo
Nov 20, 2007 | Tomtom GO 700 GPS Receiver
GPS Logo
18 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
