Richland tankless is made by Rheem. C7-76 is communication fault with remote. Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears. If problem continues, read below:
Tankless water heater, more than any other type of heater, need to be maintained. Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes. http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
if water heater heats up and after water is hot turns off you need to replace the control unit (part where all the little pipe hook into) should have an 800 number to call where you can give serial number and model number to see if still under warranty because part is as expensive as new water heater
Clear the area around the bottom of waterheater so as to allow air flow around mesh area built into base of water heater and or open unvented door passages involving waterheater. This mostly a safty issue which seldom occurs if not remedy quickly.
