Question about HP DeskJet F380 All-In-One Printer
How can i make a copy on HP Dekjet F380 by airprint
SOURCE: HP DeskJet F380 won't copy
If you can't get it to scan an image then you might have to have it brought to a repair center. How often do you use the copy function? Scanning function?
Posted on Apr 23, 2008
SOURCE: HP DESKJET F380 ALL-IN-ONE
This is the Full feature download page for XP and this one is for vista.
and here is the patch in case you happen to encounter any errors.
Posted on Sep 29, 2008
SOURCE: HP Deskjet F380 Drivers
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
You may have to install or update drivers Most of the
drivers/software I get are from a web site driverguide.com you need to fill out
a free registration then search for the driver you need download it in a format
you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Posted on Jan 27, 2009
SOURCE: I need to dowenload free the driver and software form HP Deskjet F 380
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&submit.y=7&submit.x=9&lang=en&cc=us
There u go!
Just select your OS and download the drivers you need
Good luck
Nic
Posted on Mar 01, 2009
SOURCE: My hp dekjet F380 all-in-one
Do not place any paper on the scanner and open the lid and press scan button and check if the light glows and moves forward and backward. If the light does not glow its a problem with scanner light.
Also try to uninstall and reinstall the printer drivers.
Else please refer the weblink given below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=us&lc=en&dlc=en&product=1128296
Posted on Jan 27, 2010
