Frigidaire FAC127S1A Air Conditioner Logo
A
Anonymous Posted on May 18, 2014
How do I turn off the check filter light on my Friedrich SQ08 window unit?
T.j. O'Connor
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 09, 2020
T.j. O'Connor
Contributor
Level 1:
Answers
Questions
0
Helped
6991
Points
Sundar Lolo
Level 1:
New Friend:
  • Posted on Sep 25, 2017
Sundar Lolo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6991
Points
Friedrich window units should reset by pressing both the up & down temp buttons simultaneously. Had this issue for a while until I finally called the help center. For some reason couldn't find this info anywhere online. Hope this helps !
Friedrich Window AC model UET08A11A. Where can I connect black and white plug wires with the unit?
Question edited to add 'make model (what it is)'.
Question moved from Computers to Friedrich AC.
Black is the Live wire and White is the Neutral return. When you open the unit up, it will just be a straight swap to the connection terminals.
https://www.google.com/search?q=ac+black+and+white+wires
And here is the wiring diagram for your Friedrich unit.
https://www.manualslib.com/manual/1941105/Friedrich-Chill-Premier-Series.html?page=44#manual
What could be causing my friedrich model number EM24L34 a.c./heater 23,500 btu window unit to stop blowing hot air
Here's some things that could be causing your issue.
A clogged air filter could be one possible cause.
However I suspect the units high limit switch is the culprit.
This is an image of a high limit switch for visual reference only.
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Ac works but not cooling. The thermostat dosen't work properly.
open unit an check the thermoprotector on the compressor thats the problem
Window A/C Air Filter is Soaked
There is a drain tube that usually runs to the outside that is suposed to carry the water away from the unit. It may be plugged. You could use a shop-vac from the outside to pull it through. If you have compressed air you can blow the obstruction out to the inside. Be aware this could make a mess on the inside! After clearing the drain line I would leave the unit off for an hour or so just in case there was any frost building. Then turn the unit back on. If it continues to get wet then the unit may not be leveled correct, or maybe it is low on refrigerant causing the frost on the inside.
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
