Garmin iQue 3600 GPS Receiver Logo
Question about Garmin iQue 3600 GPS Receiver
Brightness not working
I slide to maximum brigthness and nothing happens
Posted by Joseph Fernandez on
  • Joseph Fernandez
    Joseph Fernandez May 20, 2014
    The brightness control bar on the PDA doesn't work. Everything else on the screen does.
Backlight setting does nothing to adjust my screen's brightness.
Control voltage to back-light should come from the main board. The main board to your TV should be troubleshooted. Contact any service technician; or the authorized service center. This is not a user repairable work. Very skilled one; indeed.
Electro help
"why doesnt the brother printer hl3170 bright colors?
When you print a testside from the printer is the colors brigth and clear?
5210A camera not working
What kind of 'nothing' happens? The camera is designed to be stealthy, so don't expect noises or lights. Slide the switch all the way from TEST to OFF. Then slide it from OFF to ON and close the cover. At this point you should see a red LED flashing just 8 times (to tell you it's working) - then nothing.
This link has good tips: http://www.google.co.uk/url?sa=t&rct=j&q=troubleshoot+ltl+acorn+5310+no+video&source=web&cd=3&cad=rja&uact=8&ved=0CC0QFjAC&url=http%3A%2F%2Fwww.ronburyswildlife.com%2F2012%2F09%2Fltl-acorn-5210-and-6210-trail-camera.html&ei=Uox0VKPqDsblapjLgMAC&usg=AFQjCNEy5FUsjkrJuIb-kjektR_p3lW94A&sig2=7K1t-I9WL-AWU0idlZmHag
Too much brigthness
Adjust the Brightness in Power settings or Press the little blue "Fn" button next to the left "Ctrl" button. Then while still holding down the blue "Fn" button, tap the left and right arrow keys accordingly to increase/decrease the brightness.
How to lower the brigthness on my wedcam, so its not so bright.
Web camera require external lights to capture appropiate images. Adjust the rooms lights to suit the conditions.
The picture is to bright
problem in high voltage area, consult an expert
To increase the brigthness and contrast
i have a gateway laptop and i would like to increase the brightness
Monitor
hi if your pixel is permanently brigthing you can try to press gently on the screen on the bright dot to expanse the liquid, sometimes the pixel freeze on lcd monitor.
hope this helps
2answers
How can I adjust brigthness using other option than F9, because it does not work
Per the user manual, the brightness is toggled by holding the Fn Key and pressing F10. You post made no reference to the Fn Key being pressed. If using an external keyboard press scroll lock twice then F10.
Reference: http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01124713/c01124713.pdf
Brigthness Can't see picture
click on menu and try adjust the volume. just trial and error on that part. follow the standard procedure for all menu... 1st brightness, 2 contrast...etc
Top Garmin GPS Experts
Marvin
Marvin
Steve
Tom Chichester
Are you a Garmin GPS Expert? Answer questions, earn points and help others
