Mitsubishi WS-65907 65" Rear Projection Television Logo
Question about Mitsubishi WS-65907 65" Rear Projection Television
How to fix a mitsubishi ws 66907 convergence failure
Short protection / convergence failure
5 Related Answers
Anonymous
  • 39 Answers
SOURCE: Mitsubishi WS 55819 with a convergence
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
Posted on Nov 29, 2007
Anonymous
  • 116 Answers
SOURCE: My Mitsubishi WS-65313 65 inch, Convergence Problem???
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Posted on Mar 05, 2008
Anonymous
SOURCE: Mitsubishi WS-65611
My mitsubishi 65611 is about 4 years old - I am getting a green overlay color on the screen can you advise what this might be?
Posted on Jun 08, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Wont power on
did you check the two 5 amp picos that normally blow when the Ics fail? They are F9ao4 and F9a05
Posted on May 25, 2009
Anonymous
  • 14553 Answers
SOURCE: Mitsubishi WS-65857 has a trouble code 22 which I
2, then 2 blinks is short protection.
Usually this means in this set one of the two pico fuses that protect the convergence circuit is blown.
This model uses two of the STK-392-570 CONVERGENCE IC'S.
What you need to do first if you are able is remove the back cover and locate the fuses---I can tell you where they are on the board. Check both of them just like you would check any fuse. If either or both are blown----you have found your problem. The set will detect if either or both are bad that no voltage is reaching the Convergence circuit and it will shut off.
I can tell you the least expensive place to get the parts and I have step by step start to finish instructions for this repair if you are handy and know how to solder etc.
Considering the total parts cost would be under 25 dollars--if you can do this repair you can save a lot of money--most shops get 300-400 for this kind of repair----I know as I have done hundreds of these repairs----did a Mitsubishi a few days ago with the same two chips bad---about one hour for me in the customer's home.
I have photos of the fuses and location also--if you decide you want the instructions and photos we will find a way to get them to you. I am not permitted to give MY email address here--if you know what I mean.
If you have ANY QUESTIONS OR WANT the instructions etc---let me know--I am here to help and I do know a lot about this type of set.
First thing is for you to find out if either of the fuses is gone----if they are----you MUST change both chips and or fuses etc.
SD TECH
Posted on Oct 21, 2009
Error code 18 on Mitsubishi WS-55311
This is a V20 chassis, circa 2002
Available error codes for this unit are as follows:
12.....No error has occurred
21.....X-Ray protect circuit
22.....Short protect circuit
23.....Horizontal deflection failure
24.....Vertical deflection failure
Mitsubishi hdtv 1080 what are the blinking green light codes
ost models have a self-diagnosis feature to help determine shutdown problems.
To enable this feature do the following....
1) Turn the tv on and then let it shutdown
2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
This will commonly be one set of blinks followed by a short pause then another set of blinks.
This will repeat around five times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
2 - 3 = Deflection protect
2 - 4 = Vertical protect
Note: A constant blink on certain models will typically be caused by a fault in the DM model. To repair this check out site a "blinking green light kit"
1helpful
Mitsubishi 5511 getting a code 22 - short protection fault. How
Code 22 points towards a failure in the convergence section of the TV. You can get a convergence repair kit from www.TvRepairKits.com to do the repair yourself.
24helpful
Mits ws-65809 Won't turn on Blinking 2 2
2-2 is a error code that means short protection.
Usually in this set it means one of the fuses that protects the convergence circuit is shorted because of a bad convergence Ic.
I HAVE PHOTOS OF THE FUSES-- and THE PROTECTION RESISTORS- and I also have step by step from start to finish instructions for this repair in this set.
If you want the instructions and photos give me a vote here and I will be happy to email them to you and answer any questions you have. I have done hundreds of Mitsubishi sets with this problem---I just got home from doing one a few miles away from where I live.
REGARDS, SD TECH
1helpful
Ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
1helpful
I have a mitsubishi ws-55809 power comes on and then goes off
try to check it again as these are the only codes for your model.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occurred.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
WS-55511 code 22.
Check these two green pico fuses F9A04 and F9A05 to see if they have continuity, if they dont have continuity the Convergence iC and those two picos will need replacement.
I have a mitsubishi ws 65807, i get trouble code 23
The problem is most likely convergence integrated circuit failure. I recommend finding a local Mitsubishi repair center.
Convergence problem I have an intermittent vertical convergence problem. I have to shut off the TV and turn it back on to get a normal picture again. Need to fix this problem. The TV is a Mitsubishi...
Good Day;
You have poor connections on your "convergence IC's. Middle board IC's on large silver heat sink. Redo solder before total failure. Good Luck, big IRISH.
Top Mitsubishi Televison & Video Experts
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
