Question about Olympus Cameras
Olympus lens 14 45
I have two olympus 14-45 lenses and five olympus cameras that take them. Both lenses have stopped working non of the cameras let me push the shutter button and it wont focus when those two lenses are attached all the cameras work with my other lenses
Posted by Deb Finke on
steve addams
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
Contact not the same check with with camera makers
Posted on Jun 17, 2014
5 Related Answers
Anonymous
SOURCE: camera acting strange.
i have the same problem. wat did u end up doing with it?
Posted on Dec 02, 2007
David E
  • 97 Answers
SOURCE: nikon d40 autofocus
Dan62, your camera will never be able to focus on objects with no contrast. The manual specifically states this. However, you can put the AF marker over something with some contrast, half press the shutter, so that it will focus, hold the shutter button halfway while you recompose the shot, and then press it all the way.
A note to others using the D40/D40X/D60 that are having problems with autofocus: please remember that this camera will not autofocus with mechanically driven lenses. It will only AF with "AF-S" or "AF-I" lenses.
Posted on Sep 05, 2008
Anonymous
SOURCE: Camera won't autofocus
I too had D50 autofocus problems and ended up buying a new D300. I then learned that my issue was in the focus areas. The D50 has five focus areas. As you look through the lens, you will see one rectangle in the center and four to the top, bottom, left and right. You should make sure that the center rectangle is highlighted. Use the round thumbdial on the back of the camera to move the focus area.
Posted on Oct 31, 2008
Anonymous
SOURCE: "Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Posted on Feb 15, 2009
Anonymous
  • 919 Answers
SOURCE: olympus om-2 cvamera lenses
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
Posted on Apr 06, 2009
How auto focus
Most camera's, and the Olympus to work the same with auto focus. You place the AF target o the place you want to focus on. (the part that should be in focus in your picture) then press the shutter release button half and wait tip the AF conformation mark lighter up on the view finder. (the little round in on the bottom left) Then frame the picture as you want it shot and press the button complete.
I'm not sure your lens has a AF / MF switch, but that should be on AF all the time.
When you use non AF lenses, your cmarea can't focus automatically.
It should work fine with the kit lens. (lens that was originally delivered with the body)
May 04, 2014 | Olympus E-400 - digital camera
Yashica Lens 28 - 80 mm can i fix any digital camara
With the proper adapter, Contax-mount lenses may be used on several different makers' digital cameras, including Canon and Sony.
Oct 01, 2012 | Kyocera Yashica Lens Mc Zoom 28-80mm...
No problem just a question. Are olympus ever going to make a fixed non Fisheye Ultra wide angle lens like say an 8mm. The Zoom lenses in this bracket are great but, a fixed lense wood have really super...
This may be a bit off the wall, but have you thought of contacting Olympus themselves ? Fixya has no prior knowledge of equipment to be released in the future, except of course the first manned mission to Mars in 22 years time.
Jul 10, 2017 | Olympus 7-14mm f/4.0 Zuiko Lens
I want to use my OM2000 Olympus lens for my video Canon XL1, do you know Olympus has built any lens adaptor to Canon XL? Reap
Olympus did not make adapter for OM lenses to be used on Canon XL1 but, if you are looking for the lens adapter, Novoflex XL-OM Lens Mount Adapter Olympus Lens to Canon XL-1, is the lens adapter that suppose to work.
B & H has this adapter for sale.
Jun 23, 2010 | Olympus OM-2000 35mm SLR Camera
My Olympus c-730 just fell on the floor while it was on and landed on the lens. The glass lens and 2 plastic pieces came out and the lens housing is now crooked. It won't retract in or out. I tried...
I'm sorry to tell you that this means your camera is now dead.
You've broken the lens assembly, and probably the lens zoom/retract motor and gear assembly. There is no way to accurately repair them without replacing as complete sub-units: even if you could get it back together, the lens elements would be out of alignment. Spare parts have long since been discontinued.
Your camera is now about eight years old, so it's done fantastically well; very few digital cameras last more than five years. Unfortunately the only fix is to replace the camera.
Feb 19, 2010 | Olympus Camedia C-700 Ultra Zoom Digital...
Can this lens fit an olympus C 5060 ?
No, it will not. The C-5060 does not use interchangable lenses. I cannot tell from the picture that you have attached what cameras this will fit. It it was, in fact made by Olympus, it would appear to belong to their line of 35mm film cameras.
Nov 20, 2009 | Olympus Zoom Telephoto 75-150mm f/4 Zuiko...
Olympus om-2 cvamera lenses
Apr 06, 2009 | Olympus FE-330 Digital Camera
Olympus Cameras
You can use the lens from your old OM camera on the EVOLT E-410. You would need to purchase an MF-OM-1 adapter to make those lenses fit the new digital SLR camera. Also when using those lenses the camera would need to be used in Manual mode as there is no auto focus capability when using the old OM lenses.
Mar 28, 2009 | Olympus FE-230 Digital Camera
Can the 40-150mm be used in AF mode with EC14?
Tullio,
Olympus 4/3 adapter will work with OM lenses.
All in manual.
Manual focus, zoom and F stop.
[email protected]
Jan 11, 2008 | Olympus 40-150mm f3.5/4.5 Zuiko Lens
Attaching non-Olympus lenses
The E-500 body has a "bayonet" twist & click attachment for the lens. There is no way that a simple screw threaded lens can attach to the camera directly. The lens that you have are designed to screw into the front of the original Olympus lens. I have seen some of these adverts on auction sites and they are worded something like "The wide angle / Tele lenses are simply mounted in the front of the Olympus EVOLT E-500 / E-330 / E-300 standard ZUIKO Digital EZ 14-45mm lens, or any other lens with 58mm filter thread." Which maybe isn't clear enough. So the bottom line is that you need an Olympus lens to use the other lenses you have bought. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Olympus EVOLT E-500 Digital Camera
Cameras Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you an Olympus Camera Expert? Answer questions, earn points and help others
