Juicers Logo
m
marie-france herman Posted on May 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Omega 8003 does not turn on. Could it be the switch that is defective?
Is there a reset button a omega 8003. Do I need to oil the switch? It seems that I am not the only one with that problem. How to fix it?
John Marshall
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 48 Answers
  • Posted on May 18, 2014
John Marshall
Expert
Level 2:
Cheetah:
Answers
48
Questions
0
Helped
11832
Points
100
Never oil a power switch. Sounds like a defective switch and if others have the same problem go to the manufacturer website and look for a possible recall or solution.
My omega 8003 juicer will not power on
1. test for power at female end of cord? (eliminates, breaker, socket, cord, plugs, all wiring to appliance. I think this appliance is hard wired at the connection, so you may need a non-contact tester.
JUICER WILL ONLY GO IN REVERSE
I talked to an Omega tech, and he walked me through a home fix. If you open the juicer and look at the switch from below there are two sets of connections. Just move the red, blue, white connections to the opposite side (make sure the unit is unplugged when doing this).
Omega 8003 will only reverse
Hi- I wanted to use my juicer again after not having used it in at least 2 yrs. Last time (which I can't remember!) I used it, it worked. This time, all loaded up with veggies, when I turned it on it...
Just looked at mine because I thought there also might be an interlock switch
where the latch arms snap shut. There isn't one, at least on this one. Yours
might be a newer edition, so make sure the latch arms are fully seated and
snapped closed. You can also call Omega at 1 800 633 3401 and run it by
them. The reset switch should be in the pushed in position, it will pop out if
it's tripped.
5helpful
My omega 1000 juicer won't turn on - I just bought it today.
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
The left arm-clamp has come off. It seems to be different from the left arm-clamp. At first I thought I just needed to figure out how to reset the spring, but a neighbor seems to think that the arm was...
They break. The latch arm is one piece, spring and all. So if any part of it is still in the
juicer it's broken. Order a pair from Omega and have them walk you through replacing
them.
2answers
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
1helpful
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Top Omega Juicers Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Omega Juicer Expert? Answer questions, earn points and help others
