Is the it the power supply red light?
The red light may indicate that the power supply is too hot or is overheated. Therefore, you should let the power supply cool for several hours in a well-ventilated space. During this time, you should not try to turn the console back on to allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement.
Also make sure the power msupply is plugged in correctly.
You could also purchase a new power cord.
Good luck
Mick
I think its a bad power supply get a new one its $25
Power supply is nothing to do with the 1 red light fault. The problem is lead free solder used in the Manufacture of the console. The high operating temperature of the console causes fractures in the solder. The solution is an infra red reflow of the solder. This can be done at:
http://www.playbackups.com
SOURCE: One Flashing Red Light
From what I have gathered is it is most likely a defective av cable (where
you plug it in) has a chip in the cable itself that goes bad. they said
if u get a new one, most likely it will fix it, if not its a gpu prob(
but thats rare ) and if it is the gpu, that you should call the xbox
number and get them to send you a box.
There is a 90% chance it's a scaler chip problem (the "ANA" or "HANA"
chip near the AV cable connection) it can also be caused by a faulty AV
cable so check that first. In rare cases it is a problem with the GPU.
SOURCE: RED LIGHTS FLASHING
Check the cable leading to the TV is plugged in securely both ends. If it is, it is probably a faulty cable, and you will need a new one.
SOURCE: red lights flashing
3 Red Flashing lights problem is one of the most common problem of Xbox 360. You will
have to either get it repaired from Microsoft (in case your Xbox's
warranty is not expired, but one thing to note is that you will have to
wait for at least 3-4 weeks to get back your Xbox) or you can Fix your
Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
SOURCE: XBOX360 RED LIGHTS FLASH ON CONSOLE AND I GET NO PICTURE?
this problem occurs:
if you have the console plugged into an extension lead try plugging directly into the wall, but 1st, turn off your console and leave power plugged in to allow fans to continue cooling the system.. after fans switch off, carefully plug out power cord and allow cord and console to cool in a well ventilated area for 24 hours. if its still red you may need to replace your power cord as it may have overheated
