I replaced the spoiler light and it does not work.
SOURCE: Replacing 2000 toyota avalon fog light bulb
o easy enough just jack frontcar up use jackstand for safety now loo up under the bumper where fog lights sit depending on style fog light u might need to pull the whole assembly out or just twist the bulb not a hard task once u see it from underneath it is pretty easy
SOURCE: Flashing dashboard airbag light in 2003 Toyota Avalon
try wiggling wires under the front seats ,if that dont work then take the builb out
SOURCE: 2003 Toyota Camry - Both Brake lights not working
Lok in the trunk on the left side, behind the carpet for a small plastic box with a bunch of wires going to it. Look to see if there is brake light powe coming in with the pedal depressed. If so, and no power is coming out, you need to order and replace the "taillamp failure sensor".
SOURCE: 1999 toyota avalon horn works intermitely
I would suggest to you to have the spiral cable (or 'clockspring') replaced. This is the electrical unit that transfers power to the air bag, the horn and the cruise control.
It is located right under the seering wheel.
Your description of the issue indicates to me that your spiral cable is loose, and making intermittant contact. If the vehicle had an air-bag deployment, this cable-device should have been changed.
SOURCE: 2001 toyota avalon engine and vsc light stays on
You have to use a scanner and pull the code out that is causing the check engine light to come on. whatever code/codes you find are probably related to vsc light.
Good luck and keep me posted
