1999 BMW 323i Logo
K
KELLI MELTON-ALTON Posted on May 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my cd player say cd error & make cd skip
Cd player skips in all of the slots aprox 45 to 60 seconds into a song then readout says cd error what is wrong? origional player & origional magazine in the player
Steven Brandon
Level 3:
Master:
  • Master 462 Answers
  • Posted on May 14, 2014
Steven Brandon
Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117678
Points
1705
Cd magazine/ player is going bad. most likely its the springs that keep it balanced while it spins the discs
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
How can i stop my cds from skipping when driving over uneven roads?
the cd player you own its kinda old and the old laser ones skip on bad terrain movement. you need to change the player with a double laser one cd that has buffer and takes over one another in this situations. i recomment Pioneer and Sony as brands , but any new 2010 car audio systems have this kind of players u can use the usb type now or with the sd card. i know the cd quality doesn't match but hey u got bad roads on ur way simplify :) good luck !
What makes the cd skip after about 45 to 60 seconds into a song each dc in each slot does it, than a message CD ERROR lights up in the dash how do i fix this its the origional cd player in trunk &am
sounds to me like the lens assembly can't move freely all the way on the slider when reading discs. This will require you to open the cd changer unit completely to get to the lens assembly. When you get to it, check if there is anything jamming the lens from moving and the sliders, like part number labels that came unglued, screws that fell out, plastic pieces that broke, or even just leaves and branches and such. If everything is clear, then probably the sliders just need some oil and because of lack of lubrication, the lens assembly jams. Just regular sewing machine or electric motor oil will do the job quite nicely. If you don't feel like opening it yourself, you can always bring it to an electronics repair store to have it fixed. Other than that the only option would be to change the cd changer unit altogether. Hope this helps :)
Hyundai i30 cd player
hi Squeakylyssa .This goes for all cd players.
If a CD is skipping, first ensure that the disc is working properly by checking to see if it plays on another device. If so, you'll have to uncover the problem in your CD player. Some common problems include: broken parts in the device, physical damage to the CD player, dirt within the player or, most commonly, damage to the lens.
Before you do anything with the CD player, it is important to remove the batteries and disconnect the device from any power source. Wait half an hour before you begin cleaning the device.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. Place a small amount of your cleansing solution on a cotton swab or other applicator that came with a lens cleaning kit; as an alternative to lens cleaner, you can also use isopropyl alcohol. Rub the cotton swab in very light and small circles against the lens until it is clear. Allow the lens to dry, and then proceed to test the CD player. If the CD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.
A CD player has a few hardware components that may be causing your discs to skip. Unscrew and open the case of the CD player to locate the read head and potentiometer. Depending on the type of device you have, you may need to remove the bottom cover to gain access to the soldered side of the electronics board - if so, you will need to remove the whole board before you can proceed. In single-play designs, you should be able to find 3 or 4 screws that need to be removed to enable you to take out the whole optical deck. There may also be a grounding contact under the deck held in with one screw. Make sure you replace this exactly as you found it.
If your player spins for some time without finding the list of tracks and keeps returning some kind of error message once you place a CD in the player, there is a most likely a problem with the read head. The read head is represented by a small square piece that has a plastic disc sitting on top of it. Using a flathead screwdriver, adjust the plastic disc to realign the read head. This process requires you to plug in the device and hit play and stop until these adjustments fix the CD player. Make sure to put the case back on the CD player each time you test it to avoid any electrical shocks.
The potentiometer, which is positioned directly above the laser, may also be misaligned. Usually this is represented by a small square piece that has a plastic disk on top. The disk has a slot adjustable using a small flat head screwdriver. Before making any adjustments, mark the current position of the potentiometer using an indelible marker pen so that it can be returned to its initial position if need arises. You will need to gently adjust the potentiometer and locate the position where the CD player recognizes the disk again and plays it without skipping. Since this is more of a trial and error process, small rotations of plus/minus 30 degrees of rotation are usually recommendable. For safety, put the case back on the CD player each time you test. If you are happy with the performance after the adjustment then put the case back on and you are ready to rock.
Cd player flashes ''error'' when you put a cd in. It waa playing fine. Just stopped playing ejected cd.
try another cd wont play if too scratched or dirty. handle disc by edge, dont touch the surface of disc no matter how lightly you hold it, you will leave contaminants that cloud the surface. if none ever work try them in a house cd player still no joy, then discs aare no good, if they work in home player then car cd died, time for new one. heck who uses cd any more? its a hassle to change them (only 16 songs!), hassle to replace lost daamaged or stolen(borrowed by friends), skip or scratches, get a radio with usb reader/player or SD card reader, can be had for under $60 , an 8gb SD card for $25 (4,000 songs<do you even KNOW the names of that many songs?) PLus, without a cd slot the thieves should leave your radio alone, thinking its just a normal am/fm radio. goto www.dealextreme.com for great deals and FREE SHIPPING.
The cd player in my car will not play cd's anymore. even new cd's skip. a song will not play 3 seconds and then it skips out for minutes at a time.
try a laser lens cleaning CD it has small brushes on the bottom of it they go for 5 or 10 bucks it should work.
The cd skips When I put a new cd in, it begins at one then skips to much higher numbers. I have cleaned the cd. Used a laser cleaner disk and I do not know what else to do. Am very frustrated. I have dried...
The "read-ahead" memory cache is too short.
Not much you can do, short of replacing the player; however:
Does your CD player support playing MP3's?
Convert your Audio music CD's to MP3.
The same audio music is "smaller" in MP3 format than audio format. More of the song can fit in the memory cache so it is less likely to "run out" of mermory and skip.
Cd player showing error 43
Still under warranty?... check that.
Honda Civic EX 2001 CD Player
Try to use a cleaning cd to clean the cd player otherwise it may be about time for your cd player to die
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
