2008 Yamaha YZF-R125 Logo
A
Anonymous Posted on May 12, 2014
Engine light flashes 10 times - 2008 Yamaha YZF-R125
2answers
2helpful
2002 dodge intrepid sxt 3.5l. what does 10 flashes of check engine light mean?
Are you sure is not 5 flashes with a short pause in between and then 5 more flashes? Code 55 indicates the end if the diagnosis.
Reset security system
To review - the factory VATS security system will not let the engine crank or start if the wrong key is used or there is a problem with the system.
So if the engine was cranking the security system was not at fault.
You may have to get a used shop manual to get the testing procedures for a no start-stall problem.
1helpful
Chrysler town country engine light flashes 10 times
does it have coil packs? you may need to replace one
2answers
CHECK ENGINE LIGHT FLASHES 10 TIMES
Run scanner and computer for test can be MIL see the diagram
I have a 96 dodge stratus es with the 2.5L V-6. When I do the engine code thing with the key the check engine light flashes 21 times. What does that mean?
You have to count the number of flashes between delays. For example, the light flashes twice, pauses briefly, then flashes 4 times. This problem code is 24. The end of the trouble code is 55, which is 10 flashes so you have at least 2 trouble codes on your vehicle.
2004 dodge caravan. Engine light is pulsing 10 times
i would disconnect the battery terminals for 2 min then reconnect see if its fixed
2helpful
Flashing light on dashboard 98 dodge neon service engine soon light on
11= Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking for dodge odb readout. Hope this helps.
1helpful
Engine light fr ash 10 time
what your check engine light is doing is called the key dance.
The "Key Dance" is a coined term to identify a process of reading MIL fault codes stored by your cars engine computer (PCM). You cycle your ignition key from off to on (not start) 3 times leaving it on. You then count the number of times the Service Engine Soon light flashes. This combination of flashes identifies a fault code. For example, a code 21 would be flash, flash, pause, flash. All codes are 2 digits. Multiple codes are seperated by longer pauses. It should end with a code 55 indicating the process is finished.
Sometimes in newer models, the code is shown on the trip odometer. They would be P codes.
I would pull out my obd code reader and find out what it's telling me. Some parts places (Autozone, O'Reilys, etc) would even have a code reader you could borrow to check for any obd codes.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
