Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My tv keeps shuttinf off
I have a 52'' rca television n it keeps turning of the light goes green then turns off
Posted by kristy6969 on
  • Anonymous Dec 12, 2007
    I have a 27 " Panasonic TV with picture in picture. It keeps shutting off and tehn coming back on in a couple of minutes.
Willie Howell
    Genius:
  • 1,030 Answers
Does the picture ever come up?...the processor on this set shuts down the set when there is a problem. then generates an error code log. a tech should be able to read these to help determine the problem
Posted on Dec 07, 2007
Can u help me my RCA TV will not stay on keeps turning off.
Palaboy, where can i buy this part at ? R73 .0087uf h 2000 vdc. the one in red rectangle.
Jan 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't turn on! Green light one greenlight off!
Replace the flyback Its the 259296 flyback available from www.tvrepairworld.com the kit contains the flyback, associated capacitors and ful instructions on CD
Nov 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52 in. Rear projection hdtv problems
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
RCA = flyback?
I just posted a reply to you. Its most likely not the flyback causing that symptom.
Oct 05, 2008 | RCA D52W19 52" Rear Projection Television
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" RCA Rear Projection.
This will require tech repair.. the processor is dectecting problem. does the green light flash?
Nov 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
