Question about Panasonic KX-T7731 Corded Phone
This worked on mine:
Press Program, then 0
Make note of the numbers on the display (should read something like 100514 5 12:30PM).
Enter two digits for each in this order year month day.
Enter the same number that appeared on your display between the date and the time.
Enter the time.
Enter 0 for AM, 1 for PM
Press Store (phone should beep twice)
Press Program
Posted on May 14, 2010
Panasonic KXT Series Telephone System
Setting the time must be completed from an LCD Display phone at Extension 11, using the telephone keypad. This system type requires "Easa-phone" series or a 7000 series model telephone (the model number is listed on the bottom of the phone) that has one or more small switches located at the rear of the phone. Digital "XDP" phones can not be used on this system type!
To set the time:
Posted on Nov 04, 2008
Setting the Time
Step 1.
Press the PROGRAM button, then press * * 1 2 3 4
The display should now read: USR-PGM NO?
Step 2.
Enter: 0 0 0
Display: Day/Time Set
Step 3.
Press NEXT (or the SPKR PHN button)
Display: shows date (if you need to change the date, see steps 5 thru. 10 below)
Step 4.
Press NEXT (or the SPKR PHN button) again
Display: shows time example: 12:00 AM
Step 5.
Enter the hour
to change current entry, press CLEAR (or the TRANSFER button)
Step 6.
Press --> (or FWD/DND button)
Step 7.
Enter the minutes
Step 8.
Step 9.
Press SEL (or AUTO ANSWER/MUTE button) to change AM or PM
Step 10.
Press STORE (or AUTO DIAL/STORE) - Donāt forget this step!
Step 11.
Press END (or HOLD button)
Step 12.
Press SPKR PHN button or pick up and hang up the phone to leave programming mode.
Just press function button. then appears save phone book. press the down key in the loud/search button. then the words set the clock? appears. then set the timeThanga.
Posted on Dec 09, 2011
The time o n my 7735 phone is set every morning by the first call after 2AM.
Did I mention that it comes from the Key Service Unit and not the phone?
Since my particular KSU is a TAW-848, it can be programmed from any display phone or from my PC. Your probable TA-624/824 system is programmed from the phone plugged into Jack-01.
It would be better to find and read the fine manual to get instructions.
Carl
Posted on Aug 23, 2008
Use this site. It worked for me! http://www.a1so.com/PanasonicTimeChange.htm
Good luck.
Posted on Nov 03, 2008
SOURCE: Panasonic kx-t7731 phone.... How do you set the
While the hanset is on the cradle press # or * until the desired display is shown. If that does not work press the info key below that is shown on the screen.
Posted on Mar 18, 2010
SOURCE: Panasonic Phone KX-T7731. How do you set the
http://www.retrevo.com/s/Panasonic-KX-T7731-Telephones-review-manual/id/2878ag021/t/1-2/
The manual is above.
Posted on Nov 13, 2009
With the phone idle, you keep pressint the * (or the TRANSFER key) until what you want is on the display. It uses one or the other key because the 77xx phone works on more than one system.
Carl
Posted on May 11, 2010
SOURCE: Panasonic KX-T773 reads "102:" instead of date/time
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
Posted on Oct 29, 2010
Aug 13, 2014 | Panasonic KX-T7731 Corded Phone
May 10, 2010 | Panasonic KX-T7731 Corded Phone
Mar 16, 2010 | Panasonic KX-T7731 Corded Phone
Oct 28, 2009 | Panasonic KX-T7731 Corded Phone
Jul 21, 2009 | Panasonic KX-T7731 Corded Phone
Apr 06, 2009 | Panasonic KX-T7731 Corded Phone
Jul 09, 2008 | Panasonic KX-T7731 Corded Phone
16,483 people viewed this question
I have the same problem, with the same phone. How do you change the time?
Have the same problem. Can't figure it out for life of me. Anyone know?
Same problem!
I aslo have the same problem with not being able to correct the Time displayed on our Panasonic KX-T7731 phones. This is annoying and I would really like to correct it.
how to set the clock?
These phones ****. I wish I never purchased them. Absolutely not user friendly. I can't figure how to change the time, and no one else knows how to either. The manual doesn't address it either.
setting time on phone
I am able to change the date and time but once I did that for day-light savings, now the display only shows the date where it used to show the date and the time. Anyone know how to get the time to display?
