Question about SanDisk Sansa e260 MP3 Player
Playsforsure recovery mode
I got the thing for recovery mode, but i need the correct kind, not the rhapsody kind...
Timothy D
  • 626 Answers
This is for the E200 models (e250, e260, e270, e280)
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Nov 04, 2007
I cant delete any songs
The e200 series players have 2 versions, plus a Rhapsody version.
How to check your version:
On the player
1. Go to the Main Menu
2. Select Settings
3. Select Info
4. Check the firmware version, if it says
v1 it is a version 1
( or Rhapsody
Rhapsody also supports Rhapsody service and channels
USB mode is Rhapsody/PlaysForSure instead of MSC/MTP for
the normal v1
Rhapsody fonts are smooth, antialiased )
v3 it is a version 2
Having a version 2 player, songs can be deleted on the player itself:
1. In playback mode, press submenu.
2. Select the Delete Song item.
For all versions you can delete songs:
1. Making a connection to a computer first.
2. Use the Windows explorer on the computer:
Select "My Computer" on the desktop and go to the internal memory or expansion card of the e250:
Go into the MUSIC folder. Select your songs inside the MUSIC folder and select delete.
Need more information ? Just post a comment.
Dec 31, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e260...bad software
Ok, so I feel like an idiot....
The software did in fact get downloaded....the problem was me...(of course!)
I went to Settings on my mp3 player and went to Mode and somehow it had gotten switched from Rhapsody to the PlaysForSure mode. In the PlaysForSure mode it acts like a "normal" mp3 player and will not sync with Rhapsody....so my Rhapsody software wasn't needed in this mode. After I switched it to the Rhapsody mode everything worked like it was supposed to with my mp3 player.
The Sansa Sandisk e260r is a great little mp3 player. Everytime I've had problems with it...it's been me not understanding it.
Thanks!
Feb 17, 2008 | SanDisk Sansa e260 MP3 Player
Touble shooter
to run recovery mode is done by 1. Enabling the Hold Switch on the device when it is showing red 2. Press the record button then press the Menu/Power Button then it will show welcome to recovery mode on the screen of the player. I want to ask are you receiving Load Main Image Failed Switch to Recovery mode? If so reloading the correct firmware for your device will resolve this issue. Take note that there are 3 models of the sansa E200 , the first one it the Version 1 while the second one is the Rhapsody Model the one that has a rhapsody channel on it and the latest one which is the Version 2 that supports audible and SDHC cards.
Dec 05, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
Used memory i never used
With most MP3 players, some of the memory is used for system files and software. Just delete all the things you done use (i.e. pictures, playlists, Rhapsody Channels) and whatever space you have free is what you have to work with.
If you want more memory, I highly suggest a microSD card
Aug 12, 2007 | SanDisk Sansa e250 MP3 Player
Sansa c250 MP3 player
You don't need one, just go to settings, go down to "usb" mode, and if it says "playsforsure" and "rhapsody", pick "rhapsody" if it says "MTP" or "MSC" pick "MTP". Then, connect it to your computer. Go to your "my computer" folder, double click on the sansa. Then go to "tools" on your toolbar, click on "folder options", then click on the "view" tab, then go down to where it says "hidden files and folders", and check off "show hidden files". Click Apply, then OK. You should now see a translucent folder that says "music". Feel free to drag and drop any MP3 formatted music onto your computer. Please keep in mind that I've only verified this working on windows XP SP2, and that if it's not one mode, then it's the other, I know that Rhapsody is the mode you want to be in, but not so sure if it's MSC or MTP mode, try one, then switch it if it doesn't work Good Luck EE
Aug 11, 2007 | SanDisk Sansa e250 MP3 Player
Computer won't read mp3 player
Same exact problem! Sorry I'm no help > My Sansa e250 has been working fine for about a year. No problems, I can charge and sync it. > Now all of a sudden I have a problem. > My PC does not see the Sansa. Why? > I enter recovery mode. I see: > Welcome to "Recovery mode" Please connect USB Cable. > I connect the usb cable AND NOTHING HAPPENS! > Yes I read all about recovery mode on the internet. I tried it in both MSC mode and MTP mode. > How can I get my computer to see the sansa? > If my PC can not detect the Sansa then I cant get a firmware update now can I?
Jul 23, 2007 | SanDisk Sansa e250 MP3 Player
WMP11: There are no files on this device.
the player was not desing to work with wpm.
Jun 22, 2007 | SanDisk Sansa e250 MP3 Player
Jkhsadfsgaflg
You should be able to view all your songs on your mp3 player and delete any you dont want by using the software which came with it.If you havent allready done so install the cd, connect the device via usb and click on the browse all files section to edit as you wish.
May 25, 2007 | SanDisk Sansa e250 MP3 Player
Help
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Apr 27, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
77 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
