Question about Howard Miller Watches
How to get access to owners manual?
Looking for an owners manual for a howard miller grandfather clock model 610-739. having trouble getting time set light works pendulum works with new batteries for alittle bit but not consistent. it has not been used or had batteries in it for approximately 2 years but without having the batteries in
Samuel O'Donoghue
    Dedicated:
    Visited the website for 20 consecutive days.
  • 337 Answers
4 Related Answers
klgr_trout
  • 12 Answers
SOURCE: What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
Posted on May 02, 2009
Anonymous
  • 714 Answers
SOURCE: How do you determine what side of the chain that
We would like to talk you through this problem.
If you want to call, My number is on my profile.
I am available afternoon Feb 25 you are welcome to call.
R/
David
http://antiqueclock.clockstop.com/
Posted on Feb 25, 2010
Anonymous
SOURCE: We recently purchased a Howard Miller Grandfather
Just taking a stab that someone replaced the suspension spring with one that is too long, and beyond the pendulum adjustment.
Posted on Oct 25, 2010
small6363
  • 18429 Answers
SOURCE: Howard Miller Clock
Try this link
http://www.howardmiller.com/product_manuals_warranties
and this one
http://store.howardmiller.com/wcsstore/HowardMillerPublicSite/Attachment/496990_r4_Quartz_Wall_Mantel.pdf
Posted on Mar 20, 2013
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
I purchased a Howard Miller grandfather clock and its keeping time but the pendulum is barely moving. What vould be the problem?
If the clock has a real clockspring mechanism ( with dozens of visible gears), then the problem is likely it needs to be cleaned.and adjusted.
I believe the grandfather clock I was given was over wound by the previous owner. Is there anyway that I can fix this myself so that it is affordable?
If you have the patience, you could try the following.
Set the pendulum in motion - this will slowly wind down the mainspring. The clock will probably stop after a few seconds. Set the pendulum swinging again as necessary, and if you're lucky the period that it ticks for will increase each time.
You will need to be patient and persevere - what you are doing is very gently releasing the tension on the mainspring.
This is not guaranteed to resolve the problem, but it won't harm the clock or your bank balance to try. Failing that, there is a mechanical fault that is causing it not to wind and you are strongly advised to place it in the hands of a reputable and competent clock repairer.
Aug 23, 2017 | Watches
G.E. Grandfather clock The Adams
I assume you have looked on the Internet to find the manual. Even with all the trillions of things you can find, probably no one has uploaded that manual yet. I had a clock shop for over 30 years. Most grandfather calendar dials can be set by using a NEW pencil eraser. Try to use it near the center of the dial, not on the outside edge. Move the dial clockwise. I suggest a new pencil eraser because a used one can leave smudges on the dial.
Oct 30, 2017 | Watches
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 | Watches
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
How do you determine what side of the chain that the weight goes on to affect which way the clock turns - at this time the chain is completely off the wheel - clock was recently packed and moved cross...
R/
David
Feb 25, 2010 | Watches
May 02, 2009 | Watches
Watches Logo
376 people viewed this question
Top Howard Miller Watches Experts
Bruce Robin
Lisa Christine
Lisa Christine
Marvin
Marvin
Are you a Howard Miller Watch Expert? Answer questions, earn points and help others
