SOURCE: 2005 opel corsa 1.4 turn indicators
hey, let me see your vin number and check out the opel spare parts catalog to see if there are components u might be missing... it does sound very weird that the lights stay on without keys on ignition...
lets see if i can help you.
[email protected]
SOURCE: Can the flasher in fuse
if the back bulb blinks fast then the front bulb is burnt out or not making a connection. replace front bulb with a proper bulb
SOURCE: FIAT DUCATO 2005 WHERE IS THE FLASHER RELAY UNIT
2006 fiat ducato left indicator only flashes a couple of times then stops also the hazard lamps only work on right side
SOURCE: 1997 Dodge Neon left signal lights work great. Right side blinks very fast.
Has the car been in a fender bender ? check for wiring going to the front and rear lights to see if on has rubbed into a ground wire or the body. ( even if there has been no accident.)
Hi aliston , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Dan from Orange farm drieziek 1.the fuse are fine, relays I bought 3 but doesn't help.
