I need mercedes c180 timming marks
SOURCE: Mercedes Benz C180 Fault Message Brake Assist.Visit Workshop BAS
Hi there
BAS is the Brake Assist System and if there is a malfunction it would
only come into play in an Emergency stop while applying full pressure.
BAS applies full braking force because people tend to lighten up their
pressure on the pedal in these situations. I would suggest that the best thing to do is go to a Workshop or Service Center and have it checked out. Please remember to put a good rating on my profile.
Kind regards
Dustin Ellse
SOURCE: timing marks
this is an easy one to time. the timing mark for the crank is 0 degrees-do not attempt to tum crank if cam timing is out. there is no distributor on this engine-it is advanced with your intake camshaft. The intake camshaft is the only tricky part to time. Be very careful because at 2500 rpm this cam actually moves forward via cam advance solenoid. It will hit your crank if not timed properly! so with your crank at o degrees-camshafts out of head if you need to turn engine to line up crank-on the exhaust cam(your left)behind the gear(on flange) there will be a hole big enough to put a small punch in that will line up with the top of the deck surface on the outer side(to the left). Now on your intake cam(your right) it will be just the opposite. the hole on the back side of the gear flange will line up on the right with the to p the deck surface. once in line hold intake cam and turn the gear(advancer) all the way to the right)-very important. You will have to start with you intake(put chain on) then line up your exhaust and install timing chain tensioner. always turn engine 360 degrees and recheck before you proceed. At least your at top dead center and you can visually see the lobes on both cams mostly straight up. hope I have been helpful.
SOURCE: need a diagram for serpentine belt replacement for mercedes benz
Below is a link for your diagram. Best of luck!
Greg
http://www.mvreader.com/multiview/dayco/zoom.php?zoom_item=C0002R&l=n&catalog=auto&category=2
SOURCE: mercedes c180 fuel gauge giving mix reading
You can try to clean the ground behind the instrument cluster to see if that helps but most likely the sending unit has gone bad in the gas tank.
SOURCE: i need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
