I lost the key for my 1985 Honda interstate Goldwing how can I obtain a new key for my bike if possible tell me how
SOURCE: Owners Manual for 1982 Honda 1100 Goldwing Interstate
Here is link where you can download service manuals and owners manuals for free.
http://www.goldwingdocs.com/
SOURCE: my radio on my82 honda goldwing dont have sound
There are several possibilities. First, if the clock and cassette door are affected, it is a low voltage feed issue.. bad connectors, corroded terminals, etc. This voltage feed is from the 5 amp fuse in the very bottom of the relay box to the right of the main fuse block (i.e. not in the main fuse box).. clean check this fuse... If the low volume is FM only, it is internal to the radio.. in this case, another symptom is that the search/seek feature never locks on a station.. Typically this is a problem with a component on the board.. only place I know that works on them is Sierra Electronics in Troy Ohio, but others probably exist..
SOURCE: 2005 Honda Goldwing- Electrical issue. Bright
sounds like a wire has been added the wrong way or wires have damage, switch could be the culprit. Does the kill switch work? I would be checking all wires and the conectors for heat damage (melting).And fuses for all circuts. if low beam is used does key work to stop engine?
the key needs to be on to set the clock, and the radio may be set to headset or muted, Use the key to remove the radio clean contacts and try that.
SOURCE: how to replace a headlamp on a 1985 honda goldwing
I see that your question is six months old and you probably have had it answered already. I will post the proper procedure for you just in case no one has helped you.
To remove the Headlight assembly, you will need to do the following;
1)
Rotate the rear view mirrors 90 degrees so that the mirrors are facing
up and remove the bolts holding the mirrors on - you will need to
remove both mirrors.
2) Remove the windshield trim panel by placing a
shop cloth over the slot between the windshield and the headlight unit.
Insert a wide flat blade screwdriver into the slot and very CAREFULLY
lift up on the screwdriver. This will unhook the latch from the holder
on the fairing. You now should be able to remove the trim panel.
3)
Remove the louver trim panel below the headlight lens. This will give
you access to the bolts holding the lower part of the headlight assembly
(remove them and pull the headlight assembly forward and slightly out
of the front fairing).
NOTE: there are screws holding the
headlight adjustment cable mechanism to the headlight case - these will
have to be removed to take the entire assembly out. Next disconnect the headlight
connector from the headlight lens unit and you're done with the removal process.
Install in reverse order.
Hope this helps.
Oz
If you find this information useful, please vote on it. Thank You.
