Hood lever inside car won't release (don't think it is broken). Have tried to release catch at front, push down on side to unjam lever etc. not sure what to do now. Need to open to change battery! Urgently! Thanks!
Push hood back down hard,then pull on
hood release hard again.If not work,trace wire
inside as far as you can and get grips or pliers
and pul from as far up the line as you can.If it
opens as it should,you can easily unattache wire
from pull handle put a knot in wire,this will shorten it
so easier to undo next time.Infact you might try that first.
If none work which I doubt,get push to start and drive
to garage.LUCK
SOURCE: Hood won't open. Cable is broken and can't get hood to pop.
NO there is no manual way . get a good flash light and look at teh latch through the grill or from under the truck and try and pop it with a long flat blade screw driver
SOURCE: i have a broken hood latch and the hood is down
Yes, there is a way. I've had to do it three times. Once I got it the first time, 2 and 3 were easy. You're going to need a flashlight and a long screwdriver or needlenose pliers.
Get to the grill and look through with the flashlight. You're looking for the hood release cable. Follow it as far as you can to just beneath the hood latch.
Now look for the clamp on the outer part of the cable. To the left of that you should see the inner cable (the part that moves and pulls the latch). Try to either grab it with the pliers or get the screwdriver above it and pull down. You'll here it click open when you get it.
If the cable is broken or off, you're still in the right area. Look for the latch assembly, there are two or three small arms beneath. Try to move each one to the right. Be patient, you'll get it open.
Comment me back to let me know how it goes.
Good Luck
Mike
SOURCE: hood release
I had the same problem with WD-40 and man power I over came it. Chances are your latch is rusting / corroded or gummed up. What I did was to lift the passenger side up a little not to much or you will bend the hood, follow the bar as far as you can and spray the release with WD-40. Have someone pull the cable and try moving the release bar on the passengers side back and forth. It may take a little doing but it should eventually release. You know the cable isn't broken because it does release the passengers side, when you finally get the hood open make sure you spray down all three of the latches.
SOURCE: 2001 Jeep Cherokee: Passanger side hood latch is stuck
try pushing down on that side of the hood when you pull the lever (takes 2 people, or 1 with 4 9ft long arms). Keep holding the lever while you release the center latch and lift the hood. I can't promise it'll work, but it usually does. sometimes you have to play with it a while.
SOURCE: 2001jeep cherokee hood release cable broken.
try goin under the front and see if you can acces the release,also thru the front grill,theres no other way (unless you break the grill)
