How do I replace HID lamp on my 2007 bmw 335i.
Follow this link to u-tube video not the exact vehicle but the principle will be the same,or search for your exact vehicle
How to replace low beam xenon HID bulbs 2006 BMW 330i
INSTALLATION GUIDE:
BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
Parts Identification:
Projector Headlight
Halo & L.E.D.
Bottom of the Headlight:
Ballast Bracket, Halo Wires(red/black)
Turn Signal Adaptor
TOOLS REQUIRE
10mm - 8mm socket
Philip Screwdriver
Crimper/Pliers
For more information about how to install your vehicle, come visit our youtube page on
http://www.youtube.com/spyderauto
Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
STEP:
Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
Factory Xenon Headlight
Spyder Projector Headlight using Factory Xenon Lights
STEP:
PLS VOTE
SOURCE: 2007 BMW 335i
The N54 engine takes 7 quarts of oil with every oil change. But you shouldnt have to worry about that in the US because BMW covers all maintinace for the fist 4years or 50k miles. its not that hard to do though if you do need to perform it yourself.
SOURCE: Want to loacate the Brake Fluid reservoir on the BMW 335i Sedan
it should be under the hood on the drivers side up close to the fire wall
SOURCE: need to find fuse box for 2007 335i bmw
One in boot on the right hand around the battery somewhere, one under dash and could also be one under the bonnet, would be over to the left hand side of the vehicle. Not had to touch the electrics on any of these yet but generally thats where they hide.
SOURCE: how can i reset oil change on 2007 bmw 335i twin
I have a 2007 335i convertible.. my low oil light went on.is there a dip stick or something. how do i tell how low iam
SOURCE: 2007 BMW 335i just had the
It means that the engine power has been reduced - either automatically when the brain of the car has detected a mechanical problem in the engine or you have engaged the rain mode.
Usually this happens when you use a low quality fuel. But i've stumbled on rare cases when the Vanos sensor valve was the cause. The only way to precisely tell which is expensive and implies a visit to a dealer.
Testimonial: "Thank you that helped alot!"
