Question about Sanyo Audio Players & Recorders
Sanyo button doesn't open door on cassette player (System 560) the cassette tape was stuck inside & I popped the latch on the cassette door open except the button doesn't work to open door - also the tape rewinds & fast-forwards but doesn't play - when it had been working before the tape was stuck. Also the (right) bass speaker doesn't work & I've tried reconnecting the wires to test the connection & it still doesn't work.
Posted by dkartel2006 on
  • 2 more comments
  • dkartel2006 May 05, 2014
    Sanyo (System 560) Integrated Amplifier - Double Cassette Deck
  • dkartel2006 May 07, 2014
    Sanyo Stereo (System model DCX-560) Integrated Amplifier/Tuner/Double Cassette Deck - button to open cassette door latch doesn't eject the cassette tape & the cassette play button doesn't work since the tape had been playing until it got stuck inside the cassette deck & I popped the cassette door open to remove the cassette tape & cannot get the eject button to open the cassette door - also Sanyo Speaker (Bass model SS-340) doesn't work - I've tried reconnecting the wires to the speaker (still not working) how can I test the speaker to see if it works (since it had been working before)?
    I found the same Sanyo Stereo model DCX-560 to verify the type on eBay athttp://www.ebay.com/itm/VINTAGE-SANYO-AM...
    I found the same Sanyo Speakers model SS-340 to verify the type on Craigslist athttps://sfbay.craigslist.org/eby/ele/445... - except my Sanyo Speakers are better condition
5 Related Answers
Mac Gyver
  • 168 Answers
SOURCE: tape stuck
The only thing you can do, is to try to open it up very slowly.
The thing keeping the door closed is the tape that is probably wound up around one of the drive pins (silver pins),
Your tape is most likely ruined unless you know how to splice a tape back together.
After getting the door open, I would take a Q-Tip and some rubbing alcohol and clean the silver drive pins and also the pinch rollers.
This should help reduce the jamming problems if there isnt any other problems causing the drive pins to not turn. IF the pins are not turning, then it could be a broken belt problem.
Hope this helps.
Good luck.
Mac
Posted on Feb 16, 2008
Anonymous
SOURCE: URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
Posted on Sep 14, 2008
Anonymous
  • 10594 Answers
SOURCE: problem with AIWA TP-M130 micro cassette recorder can't get tape out
Following 2 pics of exploded view will help you to solve problem with Aiwa tape.
Need further help. let me know.
Posted on Oct 22, 2008
Anonymous
  • 11 Answers
SOURCE: Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Posted on Feb 26, 2009
Anonymous
  • 11 Answers
SOURCE: cassette drive turns, speakers hiss but no music
Mode switch trouble! no audio from cassette function?
Sony CMT-HPX9 has top slide tape deck and door will not open/slide.
If the cassette door/slider on your Sony CMT-HPX9 stereo system will not open, it could be caused by a few different issues. Here are a few things you can check:
  1. Check the release button: Make sure that the release button is being pressed properly and that it is not jammed or stuck. If the release button is not functioning properly, the door will not open.
  2. Check the door lock: Make sure that the door lock is not engaged. Some models have a door lock switch that can prevent the door from opening.
  3. Check the tape inside: Make sure that the cassette inside the deck is not jammed or stuck. This can prevent the door from opening.
  4. Check the mechanism: Make sure that the mechanism that opens the door is not damaged or jammed. If the mechanism is damaged, the door will not open.
  5. Check for debris or dust: Make sure that the cassette deck is clean and free of debris or dust, as this can cause the cassette to get stuck and the door not to open.
If none of these steps resolve the issue, I would recommend contacting a professional technician or Sony's customer support for further assistance.
2helpful
2answers
SANYO FXCD-500 has CD Stuck inside player. Radio & Cassette Still Work. It is Still in Dash of my Toyota 4x4 Pickup. Besides taking unit out of Dash??? Any Suggestions??
Sanyo FXCD-500 Operating Instructions Manual - ManualsLib
www.manualslib.com > ... > Sanyo Manuals > CD Player > FXCD-500 FXCD-500 CD Player pdf manual download. ... cause a deterioration in the sound or intermittent skipping some tracks during play This unit has ... TAPE OPERATION 109876 LOADING AND EJECTING THE TAPE Insert a cassette into the tape ..
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
STUCK VHS TAPE
If you know how to do this open the latch on the cassette when it stops and look to see if something got spilled into or on the tape itself.
If the unit only shuts off with this tape the cassette is the issue.
If you open the door on the tape (little square button to release the door also look (happens if you use same tape a lot and fast scan with it) to see if the bottom edge of the tape has curved waves in it--should be perfectly flat with no ripples at bottom edge of the tape.
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
1helpful
A VHS tape is stuck in my player. How do I get it out?
the tape might have stuck inside.. you need to open it and remove it on your own.. if you think its risky go to any nearby shop of electronics.. they will do it for few bucks..
Tapes stuck in the cassette and dooes wont eject on both sides
I hate to say this but you may have wrapped the spook around the player inside. I have not had much luck opening jammed doors that result from spooled up tapes.
Richard
2answers
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
6helpful
3answers
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
 Mikey
Mikey
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
