Question about Cell Phones
Nokia lumia how to add contacts?
I need to put in my phone numbers from my previous phone but it has to be done manually. How do I proceed?
Posted by CANDICE CASSILS on
fatah mankou
  • 35 Answers
Follow these instructions to add new contacts on your Nokia Lumia
  • On Start, swipe across and tap People.
  • Tap the New icon (+) at the bottom.
  • Tap Name to add First name, Surname, Title, Company name etc then tapSave.
  • Tap Phone to add a contact number and tap Phone number type to choose the type of number then tap Save.
    If you wish to add further information such as an additional phone number or an email address, tap to add more details or press Save to store the contact to the People Hub.
Posted on May 21, 2014
How to change my previous phone number to the news number
go into you profile , highlight the phone number and edit
put in the new number
Dec 20, 2016 | Cell Phones
Tip
Nokia codes and tricks
Most Popular and Useful Nokia Codes How its done: Go to standby mode (the state where your wallpaper, clock, and operator logo are displayed at the same time - press the red button on your keypad),then press the secret code. Example: if you press Quote: *(asterisk) #(number sign) 0(zero) 6(six)#(number sign) it will show you your phone's IMEI/serial number. The CODES: *#06# - displays the unique serial number or IMEI number *#0000# - shows the firmware or software version details *#2820# - Bluetooth (BT) device address press and hold the ZERO (0) button - brings you to the homepage of your wap/gprs press and hold the MENU button - launch thephone's task manager. you can then switch between active programs or terminate a running application by press the CANCEL/DELETE (c) button. *#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration. *#7370# - reprograms your phone memoryto factory default. all files will be deleted. you will be ask to input your security or lockcode to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead. turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up). *#7370925538# - reprograms your phone's wallet application. all information on your wallet will be erased and the wallet code will be removed.
on Jul 10, 2011 | Cell Phones
I cant remember my pin number. I'm not sure if they used my email address
Have you tried the email address associated with your itune account? BTW, did you restore your phone data from a backup from a previous phone? If yes, the pin number should be same as your previous phone.
Feb 28, 2015 | Apple iPhone Smartphone
Got an HTC one s from a friend and put in my SIM that o had cut down. Service works great but my phone still recognizes old phone number and won't confirm my new number
What do you mean by "recognizes old phone number"? If the previous phone number has been entered as "own number" somewhere it will be stored until changed manually, but this is used for convenience only, the phone operates on the number from the SIM card...
Best idea is to do a factory reset if you got it from a friend, this way you'll get rid of any old garbage and settings.
Regards
Stan
Nov 23, 2014 | Cell Phones
I switched phones and reinstalled Kakao talk. When I type in my email and password to retrieve my contacts it says that the password is wrong. So I tried to reset the password. I received the verfication...
it would help in answering, if you would pin-point your exact problem rather than noting all you have done . where I would presume your wrong-password has been solved, and wrong-previous-phone-number the only remaining problem .
inquire your current carrier, for they may have brought you through an interim temporary phone number to make your migration abide by inter-telecommunication contracts - meaning : you may have had another number in-between your previous old and current NEW .
Jun 09, 2014 | KakaoTalk
Nokia 5800 lock
The default code of all Nokia mobile phone is 12345... but if you have changed it or done by someone you and you can't remember the last thing is to reset/generate the current code with the help of repairing tools. Since the repairing tools are using only by tech you need to visit nearest mobile repair shop. And one thing you should remember, if you don't want to loose all your previous data please let them know before they proceed. Thanks and good luck
Nov 09, 2013 | Nokia XpressMusic 5800
Restore of factory setting code for nokia 1600
12345 is the default.If you have changed and forgot the code your only answer is to contact mobile repairing shop.Good luck
Aug 03, 2011 | Nokia 1600 Cellular Phone
I am trying to assist my mother who is blind. She lost the manual for the telephone. We need to reprogram the important numbers in the phone.
Hi cparker547,
I have looked for your manual online and had little success except that I found a site that displayed a particular model Sakar Phone. When I backed up the URL to the bellow link, there were loads of Sakar model number pdf manuals. Not knowing your exact model number I can't proceed any further, but if you can find the model number on the phone then I hope that the following link is of help to you.
http://downloads.sakarhelp.com/manuals/
Kind Regards
mparkyn
Jul 27, 2011 | Sakar Talking Caller-ID Speaker Phone
I have a vtech dect 6.0 need the manual so I can setup time and date and voice mail
You can download copy of your phones user manual from this link, just click HERE and select the proper model number of your proceed and proceed with the download.
May 24, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Resprogram speed dial numbers problem
You can reprogram them using bitpim.
Jun 10, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
114 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
