Need to know how to remove the hinge cover without breaking it, hopefully to tighten the hinge if that is possible. The monitor keeps tilting forward. HP LP2065
SOURCE: Cracked Monitor
Hi...there,
Well sure, if you don't mind pay double the prices... My advised, give yourself a new monitor, since the holidays is coming... saved you the headached and $$$...
SOURCE: I have a HP LP2065 monitor, and it is currently
Hello
OK, firstly, this problem can be due to a couple of factors. I will explain it in as much detail as possible.
Internal cracked LCD:
This is the most probable cause for these lines on the screen. Unfortunately this is not something which can be fixed without replacing the whole screen.
Damaged DVI cable:
A faulty DVI connection between the computer and the LCD screen will also cause this symptoms.
Faulty Graphics Adapter:
Lastly, this can be due to a faulty graphics adapter. If you use the on-board adapter, i would suggest that you first test the graphics adapter with another screen. Also, take out the graphics adapter and place it back in, just to make sure that there is not bad connection.
With all of the above explained, i will suggest that you start by testing the system with another screen. If the problem persists, check the connection with another cable.
If all else fails, have a look at the graphics adapter you are using.
Feel free to let me know if you need any further assistance.
Kind regards
Andrea
SOURCE: laptop hdmi to dvi monitor
Yes that will work fine
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Testimonial: "thank you I'll order the cable."
SOURCE: HP LP2065 MONITOR goes to sleep
Hi There
The Monitor setting you set through the computer, may you select the sleep mode or hibernate. Chang the mode and fix the problem.
Thanks http://pacificbits.ucoz.com/
